Go to Post Making even just one person feel safe and included in FIRST is how we know that we have succeeded. - Mr_Moko [more]
Unread 07-11-2005, 15:30
Ballam Ballam is offline
Ballam is an unknown quantity at this point
PIC16F84 -> Problem converting ASM to Hex
Hey Hey
Im not too sure if this is the right forum, but im having a few problems with a PIC16F84 microcontroller.... i have tried several of my own programs (All tested in MPLAB) and nothing happens.... i've also tried a couple of ASM files i have downloaded off the internet and converted myself.... but still, nothing happens.... however i downloaded a pre-converted hex file off the internet and it works fine.... so i've come to the conclusion that its a problem when im converting the file?
Im using default settings in MPASMWIN.exe but i have changed the processor to 16f84. Is there anything missing here?
Thanks in advance
-Ballam
Unread 07-11-2005, 16:27
Re: PIC16F84 -> Problem converting ASM to Hex
what do you mean by converting the asm file?
the asm file is the source file, it must be compiled (make or build)
and you probabally need to have some include (.inc) files in the same directory
what do you mean "nothing happens" ?
does the assembly run when you click on 'BUILD'?
do you get error messages?
did you set up the project in MPLAB to point to the right directories?
did you ADD your .asm files to the project?
Unread 07-11-2005, 17:00
Sorry for not being very precise
I mean it builds and succeeds. no errors..... but i burn it to the chip, when i run the chip all the pins all stay low...
i don't have any .inc files
Unread 07-11-2005, 17:04
did you use the TRIST registers to make them outputs?
BTW, the TRIST registers are not in the default register bank.
how did you configure the chip to run, internal clock? external RC?
Unread 07-11-2005, 18:10
external 4mhz crystal
and yes i used the TRIST registers to make them all outputs.... and even if i didn't, i downloaded a couple of sample ASM files to test with
Unread 07-11-2005, 18:15
HelloLed.asm is one i downloaded
test.asm is mine
PS: They are .asm but the forum wouldn't allow me to upload asm files
File Type: txt helloLed.txt (998 Bytes, 310 views)
Unread 07-11-2005, 20:52
neither one of those files has a 'config' statement
the config statement tells the µC whether to use the internal clock, an external crystal, an external clock input, a watchdog timer, the brownout, which pins to put various special functions on, whether to use an external reset....
So your µC doesnt know whats what - try looking for default or example code on the MicroChip website - or read up on the config register for the chip you are using (in the spec sheet for the chip).
If your µC is doing nothing then most likely its looking for a clock input, or a reset signal that isnt there.
BTW- are you a member of a FIRST robotics team, or Vex team, or did you google Microchip and just happen to find this website?
Unread 18-11-2005, 13:47
aah sorry i didn't reply
yes it was the config bits.
I just found the site on google
Unread 18-11-2005, 14:12
Originally Posted by Ballam
...I just found the site on google
very cool! FIRST students and mentors are becoming global experts on PIC Microchips :^)
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
FIRST-SME membership archiver 2001 5 24-06-2002 00:41
