communication between the robot controller and the interface
Hello....
how can we change the frequency signals of the transmitter? so i can activate 2 robots with different signals at the same time... |
Re: communication between the robot controller and the interface
Is this for VEX or FRC?
if it is the FRC controllers you must tether both interfaces, power them up, then change the dip switches that are marked as "Team Number" these switches are set in binary. After you change the team number then you can unhook the tether cord and use your radios. In order to run 2 robots you will need 2 R/C radios and controllers, as well as 2 O/I's.
If it is a VEX robot then you will need to remote controls, 2 receivers that are plugged in to your controller(s) and 2 different radio crystals (radio channels/frequencies) |
Check out pages 16-17 of this document for information on how to enable and set the additional channels. Basically you have to set the leftmost bit of the TEAM NUMBER dipswitch on the OI, connect the tether to set the robot to the same team number, and choose the channel with the CHANNEL dipswitch. |
thank you all!!! it works!!!!
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| Can We Use A N64 Controller To Control The Robot | pobots | Electrical | 25 | 18-04-2003 12:48 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| So what happened at the FIRST forum | Todd Derbyshire | General Forum | 57 | 05-08-2002 22:18 |
| Controlling a FIRST robot with a Lego RCX Controller? | archiver | 2001 | 5 | 24-06-2002 04:19 |
