New calculation of Reputation
Since I guess it won't go away, we need to do it right!
I think when you click on reputation and sort people by names, they need to be sorted by [REPUTATION/POSTS] reputation devided by number of posts So it ACCURATLY organizes people with reputation, and because I really like Karthik. And it's the right thing to do! |
Re: New calculation of Reputation
This has come up several times before, and the general argument is that we shouldn't change reputation because it doesn't really matter.
See: http://www.chiefdelphi.com/forums/sh...ad.php?t=38971 http://www.chiefdelphi.com/forums/sh...ad.php?t=29490 But here is my question: What is the intent of the reputation system? If it is intended to let people know who on this forum is experienced and knows what they are talking about, we definately don't want artificial bonuses for new posters. Should someone with 3 rep and one post really be higher than someone with 1500 rep and 750 posts? If anything, they should be listed by posts times rep. Last edited by ahecht : 06-12-2005 at 03:42. |
actually I just thought about that,and then read your post. My answer is simple. It's pretty easy to code. Have a minimal break point ~~100 posts. But then a problem comes up, what to do with all the other people below 100 posts. My answer to that is,
If posts >= 100 then stack that list above the if posts < 100 lay that list below so basically the person with the lowest rep over 100 posts is above the highest rep'd person with fewer than 100 posts. This could create more posts from people new to CD, and it ACCURATLY groups the serious member. heck even if I had 3000 posts my rep would be all green.. but that's not accurate- bc there are other members that give amazing help every day LIKE KARTHIK!! so I think this should be looked at. |
The only thing this would help would be to move up people like Jason Morrella for example, who post nothing but insightful material, but with far less frequency than others, thus leaving him farther from the top. You provide Karthik as an example. He has the 5th highest rep, so clearly rep has worked in his case. |
No matter how easy it is to code, I'm not going to waste my time modifying the vBulletin code to fix something that doesn't really matter. I'd rather spend my time on other things like CD-Media, the Attendance thing, and the imminent server performance problems come January 8th.
I stand by my previous statement: They're just dots. |
Its little colored boxes, why does it mean so much to everbody. Leave it as it is, Brandon has enough to do as it is.
#7
WOO!!
39th in reputation! 11th in posts!!!111 I am the bestest!!!1!!111! (After some other people) Brandon, I had forgotten all about the attendance thing and had to look it up. I like that more then a rep change. ![]() Wetzel |
#9
Ignoring that it's patently absurd to worry about those dots in the slightest, I certainly wouldn't want to waste anyone's time implementing the system suggested here. It's a bad idea.
What's the purpose in measuring relative usefulness as based on reputation points? If someone makes 1000 good posts in 10000 overall posts, that does not mean that the other 9000 are bad posts. Someone with 1000 positive contributions deserves more green dots than someone with 1 positive post, irrespective of how many posts they each have in total, for whatever that's worth. |
#11
It is true that the more rep you have the more you give so I think there should be a scale-like thing when one gives rep so that if you approve you can slide the scale from anywhere like 1 mato x where x is the x rep one can give another.
I think that if rep were given by number of posts, some people would abuse it and then there are those few who might have nagative rep but a lot of posts. If they were give the negative rep for a valid reason and were given positive rep because of their number of posts it would not be seen as a way to encourage them to, for lack of a better term, post better |
#12
Of course the reputation system could be modified, improved, or fiddled with from here to Tuesday.
However, as the saying goes, there comes a time to shoot the engineer and build the thing. The engineer has been shot, the thing has been built, and it still functions half-decently. If you really are worried about whether someone's rep is wrong, there's a simple solution: give rep appropriately. Over time, folks will settle to about where they should be. Last edited by Billfred : 06-12-2005 at 16:27. |
#13
Another example. I recently recieved some rep. that I simply did not deserve. I didn't do anything for it. However, it didn't move my rep. visible, which is good. if I find it moves my rep. inappropriately, I will contact Brandon to see if he can remove it. And thats where it starts: if you're not honest with yourself, the system falls at it's knees. Actually Brandon, is there a way i can remove rep. short of drawing a red point? |
#14
Edit: My tone in the original post was heavy handed.
Why do we have rep if its so unimportant is the gist of what i want to say Last edited by Dranyam : 07-12-2005 at 16:04. |
| Appropriate use of reputation points | mtrawls | CD Forum Support | 62 | 11-02-2008 14:37 |
| Reputation Deflation | Joe Matt | CD Forum Support | 26 | 22-07-2005 00:36 |
| suggestion to reduce existing reputation for upcoming season | Joe Ross | CD Forum Support | 44 | 03-01-2005 01:24 |
| Reputation and private messages | RyanMcE | Chit-Chat | 8 | 22-04-2004 07:40 |
| Reputation systems scares you away from post | Ryan Albright | Chit-Chat | 26 | 21-02-2004 16:45 |
