Go to Post My son just said, "That's the kind of thing that you talk about in strategy sessions then say, 'nah, that would never really work.'" Un-be-freaking-lievable. - Rick TYler [more]
Unread 06-12-2005, 21:15
Drew's Avatar
Drew Drew is offline
Drew
FRC #0302 (Dragons)
Team Role: Animator
Drew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the roughDrew is a jewel in the rough
Send a message via AIM to Drew
Exclamation The Pits
hey does anyone know or know where i can find the size of the pits, im just saying a general size because were working on a pit set up and no one can find the pit size so if anyone can help that would be greatly appreciated thanks guys, Look forward to seeing you all this year at competitions
check out our forum at team302.com
Unread 06-12-2005, 21:27
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: The Pits
Although not an exact dimension as pits in venues differ, large size would be 10x10 feet, small would be 8x8 feet.
If you plan for an 8x8 pit, you should be golden.
That's just a typical size, and is not exact.
Some venues have more space, some have less.. but those 2 sizes are the general consensus.
Some more details:
http://www.chiefdelphi.com/forums/sh...light=pit+size
Unread 06-12-2005, 21:37
in between teams
AKA: Luke Van Oort
Re: The Pits
I know this isn't too helpful, but I'm going to recommend having an adjustable setup. If you're making a PVC roofish thing set it up with a pair of collars in the middle of each pipe with a pipe between them that you can swap out for different lengths. My father and I use this method on out ghetto canoe outriggers in case we catch the "big one" (wishful thinking, I know) and it works perfectly, allowing us to adjust lengths and angles for the amount of stabilization we need, and drag we're willing to put up with.
Team 1219: 2009 - Mentor
Unread 07-12-2005, 23:39
TheShadow's Avatar
TheShadow TheShadow is offline
Former Resident Rebel of 66
AKA: Alex '2.0' Uhlmann
TheShadow is on a distinguished road
Send a message via AIM to TheShadow
Re: The Pits
8x8 is what we usually end up having at the regionals I've been to
Unread 08-12-2005, 07:13
Re: The Pits
I suggest you ask Technokats what size their pit is. They have had a portable enclosure for many years.
Unread 08-12-2005, 09:51
Re: The Pits
When I began my association with the TechnoKats two years ago, I think the pit frame was 10'x10'. Shortly afterwards, it was cut down by a foot in each direction because of the smaller pits at some regionals.
Unread 03-01-2006, 03:32
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Re: The Pits
They are 10x10 minus the dividers
Hows my searching? Call 1-800-Green-Dots
Unread 30-01-2006, 09:56
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Re: The Pits
I need to resurrect this thread to get some better info:
1) There now is a rule 7.7.4 that states that
For safety and because of insurance regulations, teams cannot build any structure that supports people or items for storage above the work area in their pit space. No structures should be higher than 10 feet above the floor and must safely support any signs or displays mounted to the structure. FIRST will require the removal of any pit structure that is deemed unsafe by event management personnel and local committee members
OK...That makes a lot of sense
2) BUT, it also seems like the pit perimiter is 10'x10' at the Atlanta championship, but may be as small as 8'x8' at regionals.
Is there really any standard?
3) According to the official FIRST Q&A Forum (http://forums.usfirst.org/showthread.php?t=371)
The intended table size is a 6’X30” banquet table, with no linen or draping. In some sites it may be larger, such as 8’X30”.
So it appears that the pits "may" be as small as 6' or 8' in width (yikes!)
Pits need to be set-up quickly onthe morning of the competition and can't be set-up the evening before; correct? namely, the rules stipulate that ONLY robot unpacking can occur with a small number of people BEFORE the 1st day of any event....
Some other pit thoughts we've been mulling-over
1) No roof/top over pit since the ambient lighting from gym/hall will be needed to work on robot
2) Need at least 80" to 90" of vertical clearance at front of pit/booth to roll robot on car in and out of pit area
3) Although the pit comes equipped with one table, we're thinking of re-using parts of the robot crate (e.g. the doors) as extra tables/shelves.
Other creative thoughts?
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 30-01-2006, 10:48
GaryVoshol's Avatar
Cogito ergo arbitro
Re: The Pits
The size of the table in the pit and the overall size of the pit itself are independent variables - except of course that the pit must be at least as large as the supplied table.
Surely you don't interpret that because some regionals will have 6 x 2.5 -foot tables, that will be the maximum size of the pit?
Unread 31-01-2006, 12:13
dhitchco's Avatar
AKA: Doug Hitchcock
Re: The Pits
Hi Gary,
Agreed. Each team needs to assume that the pit perimiter will be GREATER than the table size.....now, that would be funny!
Anyways, except for the Atlanta championship, there doesn't appear to be a guideline for pit size. If a team was to procure one of those pop-up tents or pop-up backdrops, it would be good to NOT have it too big which would encroach on your neighboring pits......and that's not "gracious professionalism" unless your a landlord mogul like Donald Trump!
I'd have to build a pit that is 10'x10' only to find that it's too big for most regionals, etc. Anyone else got input on this?
Unread 31-01-2006, 12:52
Freddy Schurr Freddy Schurr is offline
FRC #0204
Freddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond repute
Re: The Pits
Is the table-size like one of those tables you have at lunch or in the library? I though that the table was a lot smaller.
Anyway, we have to adjust now to fit the display under the table.
Unread 31-01-2006, 14:09
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Re: The Pits
Are any folding chairs provided in addition to the table?
Unread 31-01-2006, 16:21
Happy Birthday! EricH EricH is online now
Re: The Pits
Pits can't be set up the evening before. The only time robot unpacking can occur before Thursday's pre-entry is Wednesday night at the Championship; all regionals have it about 1/2 hour before main opening on Thursday. Plus, takedown should be quick too as you need to get it down in an hour or so (give or take a bit, depending on how you do).
Location of Pits UlTiMaTeP Championship Event 3 01-04-2005 19:46
in the pits Zippiot General Forum 46 19-01-2005 22:38
Autonomous workking differently tethered in pits, than from feed during competition. Elgin Clock Programming 12 24-03-2003 17:00
Working in the pits archiver 2001 2 24-06-2002 03:28
The best pits.... archiver 2000 6 23-06-2002 22:45
