Go to Post I'm unconvinced that this thread itself is not a performance art piece. - DCA Fan [more]
Unread 13-12-2005, 15:12
occra 23.
AKA: ryo
None #1481
not intersecting parts in inventor
i did find this while searching but im not sure if thats exaclty what i want..
http://www.chiefdelphi.com/forums/sh...n+c onstraint
well, im doing a large multipiece project and some parts are ball cups with balls. kinda like a ball and socket... and some of these tend to flip around so the cup wall intersects with the ball end screw.... i dont want this. yes i can manually adjust each and every one so they wont, but every time i have the assembly move, a couple of them spin and stuff so they have intersecting points.
is there a way to keep them from doing that? kinda like a motion limit constraint?
Unread 13-12-2005, 15:17
REVving up for a new season
FRC #2848 (All-sparks)
Re: not intersecting parts in inventor
any way you could post a screen shot of what you are talking about. I think this will help us understand a bit better what you are talking about.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-12-2005, 15:37
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Does Inventor allow you to constrain movement with physical dynamics? If it doesn't by now, it should.
In Solidworks, I can move a piece freely or choose to move it with physical constraints enabled such that the parts interact with one another as true solids and will stop at collisions.
--Madison--
...down at the Ozdust!
Unread 13-12-2005, 15:38
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Should the ball stay in the same position and orientation in the cup, or do you need it to move? You probably are using a tangent constraint, but that will not keep it from flipping out, so you might have to constrain some other features or planes (like the Origin planes or axes).
Doing that will limit (or prevent) motion, though. Usually not a problem for static designs, but might keep you from running constraint-driven animation.
Like Greg suggests, a picture would be helpful.
Pete Kieselbach
Unread 13-12-2005, 17:28
occra 23.
AKA: ryo
None #1481
sorry i dont have inventor 10 at home and cant open the project but if theres no snowday tomorrow(which i hope there will be) ill try to remembr to take a screen shot.
so well... what i have now ill post. thumbnails. well the ballcup end and ballend are constrainted with the center of each sphere portion. so well the cup cups over the ball and the center of the cup sphere and center of the ball sphere are always at the same point. allowing me to have it move. which is needed for allowing my suspension and steering parts to function. no idea if you can see the assembly i have backed up in that thumbnail.... well i guess i suck at explaining in words and will need to get a better screenshot than that lol
Unread 14-12-2005, 21:08
occra 23.
AKA: ryo
None #1481
okay i got a screenshot. i circled in green how these ballcups should be over the balls. in red i circled where they are constrainted with the center of the spherical parts, but the "wall" of the cups are intersecting with the "ball" or the screw. anyone know how to keep them from doing this?
Name:	ballcuphelp screenshot1.jpg
Unread 14-12-2005, 22:56
petek's Avatar
What would Dave do?
I would do it with a tangent constraint between the ball and socket surfaces and an anglular constraint between planes or axes on the ball and the socket. I played around with a ball joint model last night and found this to work as long as you don't need more than one degree of freedom (motion, as in constraint-driven animation). When I tried to allow rotation around the ball and yaw side-to-side, it would usually flip orientation at some point.
Pete Kieselbach
Unread 15-12-2005, 04:04
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
i believe inventor (8-10) has a function for solid parts to give them material and mass that cannot be penetrated into. it might be along the lines of "Contact Surfaces" or "Contact Set" where u would have to select which parts cant penetrate each other and instead push and pull on them if there are degrees of freedom. if i find it ill post. but im sure another inventor user knows what im talking about
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 15-12-2005, 12:14
occra 23.
AKA: ryo
None #1481
yea. all the cups move in more than one axis so the angular wont work. thanks tho....which is kinda why its a ball and socket joint..
SpaceOsc- i sure hoope you find that for me soon!!
Unread 17-12-2005, 19:53
occra 23.
AKA: ryo
None #1481
anyone figure out a good plan yet?
FRC 2005 Drivetrain and Transmission Parts on Autodesk Inventor 7 KrazyRoadster Inventor 1 23-01-2005 20:29
Changing Dimensions of Virtual parts in Autodesk Inventor 8 dan963852741 Inventor 4 19-01-2005 09:41
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
