Making the gears drive - motion
Does anyone know how to set the constraints on spur gears generated in Design accelerator so that when you rotate-move one gear it drives-rotates the other? Using inventor 10 release.
Re: Making the gears drive - motion
Go to the constraint tool, select the Motion tab, select your axes of rotation, and set your ratio. Make sure you set the relative direction of rotation too (for gears-opposite directions, for sprockets-same direction).
I maybe wrong -Osc |
| Direct Drive Four Motor System | Collin Fultz | Technical Discussion | 42 | 02-11-2006 12:03 |
| Holonomic Drive Question | Jeff Waegelin | Technical Discussion | 12 | 20-11-2005 21:23 |
| If you could change one thing.... | Koko Ed | General Forum | 48 | 31-03-2005 19:23 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Gear Making Information | Alan Ing | Technical Discussion | 14 | 29-10-2001 21:08 |
