Go to Post I've never been one for the "you did your best" and other "everyone's a winner" sayings, they don't push you, they don't get you to analyze what went wrong and figure out where to improve. - Aren_Hill [more]
Unread 19-12-2005, 07:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Cheapest and easiest way to slow down a motor
What is the cheapest and easiest way to slow down a permanent magnet 12VDC motor (think Van Door motor)? I was thinking of wiring a halogen lightbulb in series.
Unread 19-12-2005, 07:44
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Cheapest and easiest way to slow down a motor
Big resistor?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 19-12-2005, 09:52
To "slow down a...motor" could mean several things. Are you talking about applying a brake to a spinning motor? The Van Door motor's gearing probably won't break if you put a high mechanical load on it, but the motor might overheat. If you want to stop a motor quickly, shorting its input does a good job.
Or are you talking about limiting the unloaded speed? Just give it less voltage.
That's probably going to give you fits trying to characterize the voltage drop across the bulb. Halogen lamps aren't very happy about being run at lower than their rated voltage anyway, are they? I'd just use a simple resistor, or preferably choose a lower supply voltage in the first place.
Unread 19-12-2005, 16:25
I need to electrically slow down the motor. Sorry I wasn't clear on that. I only have a 12VDC supply. The motor will probably pull something like 4 amps continuous its application. It will be running continuously for maybe 5 hours. Wouldn't the resistor get very hot and need lots of cooling?
I have two or three of these motors I'll be using in the system. I'm wondering if I could get what I want by just wiring them all in series.
Also, would anyone happen to know what is inside this box? Thanks.
Unread 19-12-2005, 17:13
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I'd put money (only a couple bucks) on it containing a "chopper circuit". By using an SCR, or pair of SCR's, it will pass as little or as much of the full AC signal as you set the dial to. To understand how it operates really requires a little understanding of electronics and maybe a picture or two, but I'll try to describe it.
At full speed, the circuit allows the full positive and negative cycles of the AC to pass. When you turn down the speed dial, the circuit will only pass a equal portion of the positive and negative cycles.
Say you only want to provide the motor ~50% power, the circuit would pass 4.15 ms of the negative cycle as it approaches 0Vac and 4.15ms of the positive cycle as it moves away from 0Vac. This adds up to 8.3ms per cycle, half of the full 16.6ms normal AC cycle.
I really hope that helps. This again is where "A picture paints a thousand words" really is true.
Unread 19-12-2005, 17:27
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
[DISCLAIMER - MECHANICAL ENGINEER'S POST]
That sounds analogous to the Pulse Width Modulation we currently use (our speed controllers/victors) to control some of the motors on the robot, except that in your description you are "super-imposing" a duty cycle on an AC sine wave.
[/DISCLAIMER]
Am I even close??
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 19-12-2005, 17:37
billbo911's Avatar
[/DISCLAIMER]
Am I even close??
Gosh Stu, for a Mechanical guy, you're sharp! . Just kidding!!
As a matter of fact, I almost used the Victor's operation to try to help describe it. There are some subtle differences, but that is what both of these circuits do, modify the duty cycle of the power supplied to the motor.
Unread 19-12-2005, 17:42
I'm wondering if there is anything from an automotive location that would do it. I believe the motors are actually windshield wiper motors, or they could possibly be window motors. How does a car's windshield wiper system get the different speeds? Does it have all different resistors to get the different speeds?
Unread 19-12-2005, 17:54
in between teams
AKA: Luke Van Oort
<Off topic> Are any of the rest of you wondering what sanddrag is up to? The smoke and now this. </off topic>
Sanddrag, I don't know what wipers you're talking about, but I think that they just switch the motor on and off, I think they're verying wipe frequency, not speed.
Team 1219: 2009 - Mentor
Unread 19-12-2005, 18:08
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
He's helping to build a parade float for the Tournament of Roses parade on January 2, 2006.
--Madison--
...down at the Ozdust!
Last edited by Madison : 19-12-2005 at 19:28. Reason: The parade is apparently on Jan. 2. Isn't it typically on the first?
Unread 19-12-2005, 18:10
I am part of the crew building the Cal Poly Universities "Enchanted Reverie" float for the Tournament of Roses Parade. You and a few million other people can look for it on TV January 2nd! As a note on the smoke, I don't think it is going to work out for this time. The deadline is too quickly approaching.
For the wiper control, yes, I don't know what I was talking about either. I guess in southern California I don't use my wipers often enough to remember what they look like when they move.
Unread 19-12-2005, 19:15
occra 23.
AKA: ryo
None #1481
no.. for my truck i have a high speed and a low speed and a whats it called.... wipe. pause. wipe. pause.... with variable pauses. so well there are 2 speeds at the least on a cheap truck. so for i unno... say.. wrxs just might have more speeds? at least the rally ones have veryy fast wipes.
Unread 19-12-2005, 19:41
another easy way to drop voltage: silicon diodes have a fixed 0.7V drop. If you have diodes that can handle the current, you can put them in series till you get down to the voltage you want.
BTW, the easiest and cheapest way to slow down a motor is to wack it with a sledge hammer,
and the 'right' way to slow down a DC motor is to increase the strength of the magnets. The stronger the field, the more torque it will have and the slower it will run (due to the EMF voltage).
Unread 19-12-2005, 20:47
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
The wipers have resistors for the different speeds. If equipped with intermitent wipers (almost all vehicles these days) then there's also a timer, this is what greencactus was mentioning.
Depending on the vehicle the resistors and timer can be part of the switch, a separate unit somewhere, or part of the wiper motor. My 1987 Chevy Caprice has a circuit board mounted to the wiper motor where all this is.
The blower motor (for heat, defrost, a/c) for a vehicle also uses resistors to get the different speeds. These resistors would be attached to a single board in the heater box. They are in the heater box to help keep them cool with the moving air.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 20-12-2005, 07:39
Sanddrag,
So many questions, so little time. You can go to a junk yard and get a couple of wiper controls. They are big resistors (low ohms but high power dissipation) and they should be easy to wire up for what you need.
The router control device you saw is like a lamp dimmer for AC motors only. It contains a Triac that switches on for only a portion of the AC sine wave cycle.
Did you need to run all motors at the same low speed at the same time? If so you could buy a variable voltage supply. If the motors don't need direction control, a pot and a power transistor will likely do what you need. Make sure that the transistor is attached to a heatsink of some type. 2n3055 should do but anything Radio Shack has in NPN 5-10 amp range should work. Try a 10K pot to start and see what results you get. I think the junk yard is the best bet.
