Integral Window for PID Control
How do you determine how many error samples to include in your PID model? For the derivative portion you presumably just use the last sample (or is it common to do the average difference over a few samples?). There are well defined methods for tuning the constants in a PID algorithm, but how do you choose how far back the algorithm should look?
Re: Integral Window for PID Control
time window for the integral feedback. You start with zero integral when you activate the control system and let the time integral of the error be a running sum. The question is when to start the integral feedback. If the proportional and derivative signals are arranged to produce a critically damped system the system will not overshoot at all (as a PD system). Delaying the start of the integral signal will limit any overshoot that the integral signal injects into the system. With regard to averaging the time derivative signal, you have to be careful about the time delay when you do this. If you use an average from too far back in time you could produce a sizable delay. If you delay the signal too much you will get growing oscillations instead of the damping that you want. Have fun, Eugene |
I used a running sum for my error, but with the current sum cut down by a % each loop, so that the more recent error has more "weight". You also get the advantage of not having to keep and manage an error array for a time window.
// Integral control Integral_Sum = (Integral_Sum *995) / 1000 + Err; Integral_Counter = (Integral_Counter *995) / 1000 + 1; Iout = Ki * (Integral_Sum / Integral_Counter); Sums from 38 loops (1 second) ago to now make up 17% of the running sum. 0.995^38 = 0.827 Sums from 114 loops (3 seconds) ago to now make up 43% of the running sum. 0.995^114 = 0.565 Sums from 191 loops (5 seconds) ago to now make up 62% of the running sum. 0.995^191 = 0.384 Sums from 382 loops (10 seconds) ago make up 85% of the running sum. 0.995^382 = 0.147 Sums from 763 loops (20 seconds) ago make up 98% of the running sum. 0.995^763 = 0.022 You can change the 0.995 to make your running sum more recent or keep older sums more important. I haven't seen this online anywhere, I don't know what it's called or if it even works yet, but it made sense to me. If anyone sees anything wrong with it let me know. |
| Concept of PID explained | ConKbot of Doom | Technical Discussion | 11 | 27-01-2008 00:11 |
| Pre-manufactured control box for FIRST | Ben.V.293 | Technical Discussion | 19 | 22-08-2005 12:53 |
| 2005 RadioShack Innovation In Control Award--What Won? | Billfred | Control System | 8 | 12-06-2005 01:51 |
| What do you wish you knew about the new control system? | Joe Ross | Control System | 2 | 09-01-2004 21:47 |
| Looking for window kit parts | archiver | 2000 | 2 | 23-06-2002 22:50 |
