Go to Post I urge teams to look beyond what you are given in the kit of parts and strive for more - sanddrag [more]
Unread 08-01-2006, 22:36
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
Motors for ball launchers
I was just wondering how (if you're willing to say) other teams are thinking about shooting balls to the center goal. We are leaning to a baseball shooter type machine (2 spinning wheels). We're trying to pick the main motors, and will most likely use the new mini-bike motor. It seems to draw less power, and have a pretty decent amount of force. That type of shooter would also allow for a fairly rapid succession of shots. Is anyone thinking of any other kind like pneumatic, catapult, or something I can't think of?
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 08-01-2006, 22:47
occra 23.
AKA: ryo
None #1481
Re: Motors for ball launchers
gravity powered oldschool trebuchet DUH
i dunno. need to look into the specs of each motor.
Unread 08-01-2006, 22:51
DonRotolo's Avatar
Back to humble
FRC #0832
Be sure to serach the rules/strategy forum, there's a lot of discussion on the method.
As far as motors go, you need to determine the energy needs, and pick a motor that will supply that. First, what is the mass of the wheel(s), and how fast do you want them spun up to speed after autonomous starts? Then, how much energy (think inertia) will launching a ball remove from the system, and in what time do you want that returned by the motors?
If you're using a wheelbarrow tire, then the big CIM might be a good choice - it'll get the tire up to speed real quick. But, it'll be just loafing along after launching a ball, so maybe it's too much??
Anyway,. the point is: Do the math. Make reasonable assumptions and guesses. That'll help you decide.
As far as other ways of launching balls: other threads have discussed this, one or two wheels seems to be the most common approach.
Don
Unread 08-01-2006, 23:56
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
baseball launchers
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 09-01-2006, 15:03
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
As of right now, MORT has considered a few options:
Throwing arm; probably unreliable
Dual wheel design
Single wheel design (probably prone to jamming and unpredictable spin on balls)
The other consideration with a dual-wheel design is whether to mount the wheels on the sides or the top and bottom of the ball.
Personally, I think the most reliable design for a shooter is one or two wheels (heavy for high momentum) on either side of the ball (horizontally). The wheels will align the ball as it feeds and the forces are balanced on either side to prevent spin.
In terms of motors, the big CIMs have been allocated to DT, so it looks like an old CIM for the shooter.
Any comments?
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 09-01-2006, 15:13
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
A few things you need to keep in your head are:
1.) Mass of the wheel.
2.) Power needs of the motor
3.) Time between balls being launched (since the motor will slow down)
Well looking through this i guess all of those are already posted.
Good luck
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 09-01-2006, 15:17
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Okay, if people feel like waiting till this evening, I've worked up a spreadsheet to tell you how long it'd take to spin up a wheel with a given motor, assuming full 12V sent to it. I'd post it now, but I originally coded it with the 3 speed Dewalt tranny in mind, but that seems slightly overkill at the moment. It makes the sheet a little messy, though.
Unread 16-01-2006, 00:12
I'mwithstupid^'s Avatar
I'mwithstupid^ I'mwithstupid^ is offline
I'mwithstupid^ is on a distinguished road
wow guys, why dont u want spin? Hasn't anyone ever heard of riffling, the thing that increases accuracy and distance with bullets? The correct spin repeated effectively will increase ur consistency. Geez guys, u gonna be out smarted by a red neck hick?
Unread 16-01-2006, 00:25
MaxChan's Avatar
MaxChan MaxChan is offline
Junior Member
FRC #0613 (Robowarriors)
MaxChan is an unknown quantity at this point
I'd think that the difficulty lies in the repeatablility of placing spin on the ball. I don't think that it would create much of a noticable difference, though.
Unread 16-01-2006, 03:54
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
In order for spin to be helpful it has to be spun correctly. Topspin won't get you better accuracy. We thought about doing a regular two-wheeled baseball shooter except offsetting one wheel to produce some spin. But we decided it would probably take away from the overall power of the spinning wheels. Or just not work.
Unread 17-01-2006, 10:29
eternalfire1244 eternalfire1244 is offline
Steve
FRC #1244 (Viking Robotics)
eternalfire1244 is an unknown quantity at this point
Send a message via MSN to eternalfire1244 Send a message via Yahoo to eternalfire1244
using rifling for a round projectile is more or less useless, as the ball spins through the air it makes a larger and larger spiral. The concept only seems to work on cylindrical objects. At the distances we will be engaging at I doubt that it will be a huge problem. The only spin that I am concerned about is through the horizontal axis.
my $0.02
Unread 17-01-2006, 13:08
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
my $0.02
Yep,
Rifling is used for cyclindrical object because the area is smaller one way. pi*R^2 is less than Diameter*Length. For a sphere it is pi*R^2 regardless of orientation.
Basically rifling keeps the object oriented the right way to reduce drag.
In simpler thinking, It's the reason why you wouldn't want to drive a 18-wheeler sideways. Or why it is more fun to drive a car through the Flint Hills than my extended Aerostar van.
Unread 17-01-2006, 14:53
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
I'd say a CIM would be one of your best bets, although I do like the mini-bikes.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 18-01-2006, 16:27
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
my $0.02
It is my understanding that rifling a spherical bullet IS effective. The spin axis parallel to the direction of flight helps maintain a straighter (more accurate) path because the projectile has ROTATIONAL INERTIA. Because of this resistance to a change in rotational motion, the bullet will spin about the axis and the axis will not change direction, keeping the path straighter.
Of course, you are right in that the distances and speeds we are talking about, rifling spin will have very, very little effect on the path of the ball compared to the inital launch velocity.
-Mr. Van
Coach, 599
Unread 18-01-2006, 20:17
Steve
"The spin axis parallel to the direction of flight helps maintain a straighter (more accurate) path because the projectile has ROTATIONAL INERTIA."
This is a valid argument, although in my personal experience the rotational inertia causes another type of inaccuracy- corkscrewing. This is especially true with barrels that are slightly bigger than the projectile, the ball bounces in the barrel and randomly bounces out of the muzzle. This action increases the "corkscrew effect".
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
