4.3.4.1 - onboard laser?
So, my question pertains to 4.3.4.1.
If I just tape a laser pointer to my bot that only turns on when I press the button on it is that legal? Thanks, - Erik |
Re: 4.3.4.1 - onboard laser?
P.S. If it's not against the rules it should be... |
So I pose it again, anything illegal? |
Actually, the laser qualifies as a MECHANISM. One of the PARTs in that mechanism is the laser battery. This battery is not allowed, because it is an energy source.
It's all in the manual, pretty clearly. |
Not to mention the fact you can't "tape it to the robot" like you say, without violating <R33>.
#7
If you were to power this mechanism through the robot battery, then what? Matt |
#8
One should note that there is such thing as an "eye safe" laser, which transmits at a frequency that doesn't harm the eyes because it is absorbed by the cornea rather than being focused on the retina. As long as such a device is used in good faith (you know, as in it isn't green and it isn't shone on the other drivers), none of Mike's above cited rules appear to be violated.
#10
I would say no, citing the first question the flowchart asks: "Is the part a safety hazard or likely to damage robots, the field, or interfere with the humans or the controls?" --> YES --> No!! It may not be used. |
#11
if you are in fact using it to aim, one could plausibly have the robot do some math for you using the angle that the CMU cam is at (my team programmer says that it does that this year) and do some trig using the height of the target the CMUcam follows and how far your robot shoots to have the robot light up a fire at will light on your control area. Or, even better, you could have a robot that fires at will when a shitch is flipped once it checks that it is within the correct angle ranges for the ball to go in. (again, the angles (verticle and horizontal) are returned to you by the CMUcam)
#14
Of coarse if it started being shone at another driver it would fit in what you mention and the robot would be subject to shut down, but legally is such a aiming mechanism against any of the rules? I'm also assuming that the light is sufficiently guided so that none of the glare of the light finds it's way to the player station. I think you would have to narrow the beam much more then a standard flashlight to get any real indication of your cannon position but it is a good guide if you either can't get the camera to work or if it breaks during normal game play. |
| laser pointer | 1574aviad | Technical Discussion | 9 | 20-02-2005 20:25 |
| Second Annual Laser Quest Lock-in! | Gui Cavalcanti | Off-Season Events | 3 | 29-04-2004 23:33 |
| laser radar with BS2p using RS232 problems... | chei_UCF19 | Programming | 6 | 26-02-2004 15:21 |
| Onboard Camera? | XRaVeNX | General Forum | 18 | 03-02-2003 20:28 |
| laser guidence for a basic stamp brained valve cover racer | Andrew Wyatt | Technical Discussion | 1 | 05-06-2002 00:14 |
