Go to Post "Yes, I'd like to Super Size my speed controller combo and add a jumbo distribution block, please." "You want fries with that?" - Travis Hoffman [more]
Unread 12-01-2006, 22:52
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Jerky Tracking?
Well we've set up the camera, and using LabVIEW it tracks beautifully, it's wonderful, but thats driving its own servo. Kevin's code does a great job of searching and finding the light...then goes haywire.
Once locked the camera starts violently pitching itself back and forth and up and down until one of the PWM cables pops.
We're using the code verbatim, so....I'm not sure...the mounts assembled right.
What else should we check?
Thanks.
Matt Krass
Unread 12-01-2006, 23:32
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Jerky Tracking?
Thanks.
How do you have the camera mounted? Did you look in the header files for a documented parameter that might explain this wacky behavior?
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2006, 23:37
Matt Krass's Avatar
AKA: Dark Ages
Re: Jerky Tracking?
We're using the kit mount, we tried inverting the camera and that seemed to improve it somewhat but it still jitters way too much to be useful, I've fiddled with the settings but I can't find any noticeable effect. I've managed to slow down the scan speed while searching, is there a parameter I might have missed that controls how fast the servos try to error correct/center when it see's something? It looks like a constant overshoot kind of problem..
EDIT: Looking again after a good break I found some gain parameters to adjust, I'll see if those help.
Matt Krass
Unread 13-01-2006, 00:15
FRC #2429
Re: Jerky Tracking?
You can also tweak the gain values via the tracking parameters menu. Just remember to save it to EEPROM once you're happy with the value(s).
-Kevin
Kevin Watson
http://kevin.org
Unread 13-01-2006, 00:23
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Jerky Tracking?
Something I didn't really notice in the docs:
Does the streamlined version check the EEPROM values saved by the bells and whistles version?
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 13-01-2006, 00:50
FRC #2429
Re: Jerky Tracking?
No, it only uses values from the header files.
-Kevin
Kevin Watson
http://kevin.org
Problems with tracking Shinsa Programming 2 07-02-2010 14:35
'tracking' flag zdeswarte Programming 3 20-02-2005 13:53
trouble with beacon tracking code [53] opticruzer Programming 9 27-01-2004 12:19
IR tracking nzj1 General Forum 3 26-01-2004 22:46
Tracking Canadian teams at nationals! blueWarrior Championship Event 15 15-04-2003 21:03
