Go to Post If the pattern holds, it's a bizarro year. - GeeTwo [more]
Unread 13-01-2006, 09:10
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
PWMs Active in Programming Mode?
We finally hooked up our new FRC to a pair of VEX servos last night to tinker around with EasyC (we've been messing with LabView and the camera standalone). While walking through the Getting Started section of the help file, we needed to put the FRC into Programming Mode to receive a download. On each occasion, shortly after entering Programming Mode and before actually initiating the download, the servos we had connected to PWM01 and PWM02 went spastic for 2-3 seconds. This was, consistently, about 5-10 seconds *after* the controller was indicating that it was in programming mode.
Has anyone else seen this or should I be calling IFI for a replacement controller?
Lynn (D) - Team Voltage 386
Unread 13-01-2006, 09:20
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Re: PWMs Active in Programming Mode?
I would call IFI and ask them about it. The servos normally reset when the RC powers up, but they shouldn't go 'spastic.' If there were motors hooked up, that would make me think the robot would go nuts. If that were the case, I'd definitely ask for help or a replacement from IFI.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 14-01-2006, 07:35
I have posted to IFIs support forum, but they have not yet answered my question.
Unread 13-01-2006, 09:21
Back after 4 years off
FRC #5279
Did this happen before or after you downloaded the code. If it was before the code was downloaded reinstall the master code on the controller an try again. If it is after the code is downloaded then check the code and make sure no one changed any thing.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 14-01-2006, 01:53
It happens before downloading the code. We learned tonight that if we disable the robot via the competition port, it does the same thing after a short delay.
Where can I get the 2006 Master Code? The latest I could find was the one from April 2005 and I didn't want to load something that old into a new controller set.
After our code is loaded, the robot behaves itself completely. It is only when it is disabled or in programming mode that it get wierd.
RS-232 Programming port as an active interface Goose Programming 1 03-04-2005 15:40
Stuck in programming mode sudeepr71 Programming 5 20-02-2005 01:01
stuck in programming mode Shu Song Control System 2 29-04-2004 16:44
pwms 13 and 15 in autonomous mode Chris Bright Programming 1 24-02-2004 22:25
Brake mode on pwm's snowdragon General Forum 4 23-02-2004 19:11
