Go to Post FIRST is like a big roller coaster, that can only be experianced if one takes a ride which can become a liftime experiance. - activemx [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2006, 15:32
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Ball Damage
Hi,
After test firing for an hour (about 150 test shots) we stripped off about 10 - 15% of the surface of the ball. The ball is still useable but sure is ugly. Any idea if there are limits to ball damage by a bot? Shooting a ball one time causes no noticeable damage...but 150 it becomes obvious to everyone.
Regards,
ChuckB
Team 342 Programming & Control Systems
Good luck and have fun!
Unread 13-01-2006, 15:36
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Re: Ball Damage
Generally in the past: Unless your robot rips a couple of new balls to pieces, the Ref usually won't even question it. They expect wear and tear. So if you mess up an old ball, no worries.
They'll replace balls as necessary to make sure they are reasonably consistent, but you have to take some variance into account in your design.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 13-01-2006, 15:41
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
Re: Ball Damage
i noticed that the part where the 2 colours meet seperates very easily, and once there's a rip it only gets worse.
however this dosn't take out any chunks of the balls, the foam stays intact.
by limit i guess you mean when a ball would be taken out of the game?
i think as long as the ball keeps it's original shape it'll be kept in play.. since balls can be scored on either net i doubt some colour wear would get them replaced.
unless they are worn down creamy coloured balls of foam?
anyways i apart from them being ugly i don't think you should worry.
Unread 13-01-2006, 15:58
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Ball Damage
Ball wear is a definite concern, especially for shooter bots. Any non-sphericalness (yeah, I just called up Noah Webster and had that put in the dictionary) will distort the ball's path. I've seen quite a few pics and movies around with people using belt sanders etc. to move balls - while I realize these are only mockups, similar methods will be used. So be advised - don't design a robot that is based on perfectly round balls.
Hi!
Unread 23-01-2006, 13:35
Kilrath Kilrath is offline
FRC #0930
Kilrath is an unknown quantity at this point
Re: Ball Damage
The balls are not perfectally spherical at the start. They are close but not perfect. We like a couple other teams have found the ball not to be perfect but it doesn't seem to affect how they shoot. So unless you are very anal about the shooter shooting perfectally spherical balls you should be fine.
Unread 26-01-2006, 01:45
dtengineering's Avatar
AKA: Jason Brett
Re: Ball Damage
Earlier I posted that our shooter was seriously ripping up the balls and was seeking to hear if other teams had developed shooters that did not.
We have since gone back to the drawing board and have replaced the wonderfully grippy 8"x2" (actually closer to 9" dia.) Skyway pneumatic wheel with two 8" skyway kitbot wheels and rebuilt the turret to account for the reduction in diameter.
Our ball velocity is down a bit... but that's not a bad thing seeing as how we were well over 12 m/s before. Tonight we hit the 3 point goal from 20' out about 8 times out of ten (the variation was due to how the ball was fed in, I believe... we'll call it human error) with no noticable ball damage.
A note to teams that are ripping up the ball... the rethink and redesign advice is probably good advice. Ball shooters that do essentially zero damage can be built. Ours is a single wheel design (the two skyway wheels are on the same shaft) and it sounds like there are many other zero-damage designs out there.
Thanks to the other teams that have posted their successful zero-damage ball shooting results... it was sounding for a while like EVERYONE was ripping the ball to shreds like we were.
Jason
Unread 27-01-2006, 13:14
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Ball Damage
My team is also using a two wheel design, but the wheels are about 5" apart center to center, and are angled inward. Before we angled them inward, the sharp rubber corners would cut into the ball as it was being shot. Now with angled wheels, we have tandential contact, so it works beautifully. Plus having the wheels out like that reduces the height of the shooter, and gives you a mechanical advantage because you're pushing the ball from closer to its center. With six inch wheels direct driven off the CIM, we're getting exactly 11.6 m/s, and about 32 feet at 45 degrees. And zero damage to the balls.
Unread 13-01-2006, 16:01
REVving up for a new season
FRC #2848 (All-sparks)
Re: Ball Damage
In 2001 the black balls which were inflatable became eggs. First just left them on the field as long at they were inflated. I suspect that balls will remain on the field as long as they can roll.
also just out of curiosity what kind of thrower are you using when you are messing up the balls, might it have something to do with the material the ball touches?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-01-2006, 16:12
Billfred's Avatar
Billfred Billfred is offline
Re: Ball Damage
For reference, I put a question in at FIRST Q&A to see if they've set a criteria to determine when a ball is Too Pooped To Play. We shall see what we're going to have to deal with.
Unread 13-01-2006, 20:17
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Ball Damage
Also teams need to consider how much the ball will be broken in...
a new ball when compacted will shoot further than a used ball that isn't as tough and squishes easier
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 14-01-2006, 21:39
teh_masterer's Avatar
teh_masterer teh_masterer is offline
ub3r 1337 R0b0 d00d
AKA: Chewy Hollaway
FRC #1529 (Cyber Cardinals)
teh_masterer is an unknown quantity at this point
Re: Ball Damage
we played with the ball (in dodgeball fashion) around the shop and saw how much the ball was damaged after a few hours. Besides a few gashes and holes in the ball we seemed to make the ball alot less rounder than it was. Good thing we ordered an extra 24 we will have plenty more to use. When does first think the ball has expired?
Pwning n00bs since 2004
my hands are shakin'
my hearts a beatin'
im still shootin'
and im still gettin headshots!!!
BOOM, HEADSHOT!!
BOOM, HEADSHOT!!
Unread 14-01-2006, 21:44
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Ball Damage
Originally Posted by Official FIRST Q&A by GDC
An official point of a ball not being useful has not yet been determined.
FIRST will attempt to get the maximum use of all playing objects, while still ensuring the objects are useful to teams.
Teams should not expect that all scoring objects will remain in an "as new" condition for the entire event.
http://forums.usfirst.org/showthread.php?p=473
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 14-01-2006, 21:49
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
Re: Ball Damage
What if a ball has split in half during a match. Like if it splits in half from being run over or just over use or shot too many times. How would FIRST score the two halves of the ball?
Unread 14-01-2006, 21:59
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Ball Damage
Well, if they were destroyed during firing, they probably wouldn't roll down to the camera for scoring. If they were run over, they probably wouldn't ever make it into a scoring area. Regardless, we will see a half of a ball score eventually.
-Sir Francis Bacon
-Albert Einstein
Unread 14-01-2006, 22:09
Leo 1529's Avatar
AKA: Tzu-san
Re: Ball Damage
I hope im there to get it on video so i can put it in this years robotics movie.
What about balls that get gashes or holes that might be still be playable. would anyone think that the balls should be allowed to still be used with some chunks taken out or gashes in them?
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
Low quality 2X ball? Rob General Forum 16 22-04-2004 22:36
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
