Go to Post Too bad MI isn't allowed to participate in FTC - Cory [more]
Unread 14-01-2006, 12:04
JSonntag JSonntag is offline
FRC #0486 (Positronic Panthers)
JSonntag is on a distinguished road
Send a message via AIM to JSonntag
Interrupts
Could anyone help us with Interrupt Code for use with optical encoders? We are placing two of the small, yellow banner sensors next to the wheel, which will be covered in a sheet of paper with alternating black and white stripes. As the wheel turns we plan on detecting the change between black and white, and by comparing the counts for both the left and right wheels, we should be able to program precise turns and straight lines.
I am aware of some of the problems with Interrupts, therefore I only want to increment a counter when the state changes. The Optical sensors are plugged into rc_dig_in03 and 04.
Anyone have any ideas.
Unread 14-01-2006, 12:43
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Interrupts
I should work if you use this code for the interrupt handlers:
void Encoder_3_Int_Handler(unsigned char state)
// Encoder 3's phase a signal just changed logic level, causing this
// interrupt service routine to be called.
if(state == 1)
Encoder_3_Count += ENCODER_3_TICK_DELTA;
void Encoder_4_Int_Handler(unsigned char state)
// Encoder 4's phase a signal just changed logic level, causing this
if(state == 1)
Encoder_4_Count += ENCODER_4_TICK_DELTA;
Adjust ENCODER_3_TICK_DELTA and ENCODER_4_TICK_DELTA per the instructions in encoder.h to get the counts to go in the proper direction.
-Kevin
Kevin Watson
http://kevin.org
Encoders, interrupts, and edge-triggering issues Alan Anderson Programming 6 11-03-2005 16:06
Global Struct Arrays and Interrupts Orborde Programming 5 18-02-2005 22:34
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
INT2 and INT3 interrupts not working Mercutio Programming 4 01-02-2004 13:27
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
