Go to Post I don't thinks shorts should be allowed in the pits. Remember to insulate all of your wires! - Jalerre [more]
Unread 14-01-2006, 15:15
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
corrupt CPU?
I am not sure, but I think I just corrupted my CPU (as far as I can tell). I was loading some code into the cpu (the code was in the process of loading) when the reset button on the CPU was pressed. Now it is permanently in the ready to be coded stage (programing light solid orange). I have tried disconnecting ALL power (main and backup), restarting IFI Loader, disconnecting the wires and reconnecting them but nothing seems to work. I am worried that I may have a corrupted CPU now.
Unread 14-01-2006, 15:30
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: corrupt CPU?
Try doing a full reset of the RC:
Originally Posted by IFI
With main power applied, press and hold the Reset and Prog buttons at the same time. Release only the Reset, while continuing to hold the Prog until the Battery Power LED becomes solid green. Now release the Prog button. Now press and release the Reset button.
Unread 14-01-2006, 15:31
Windward's Avatar
FRC #1452
Re: corrupt CPU?
Never Mind. After waiting 1/2 an hour, it went back to normal.
Unread 14-01-2006, 15:33
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: corrupt CPU?
Heh. Two quick little solutions to nearly all computer/electronical problems I've ever had.
1) Reboot.
2) Come back later.
Glad to see #2 worked
http://www.mikesorrenti.com/
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
cpu ivanslost Programming 1 15-02-2003 23:23
ChiefDelphi.com corrupt? -- ZOUNDS!?!? archiver 2000 8 23-06-2002 22:18
