3/4" bore x 1/2" stroke Bimba Cylinder model
Does anyone have a good Inventor model of this cylinder?
EDIT: Also, if anyone happens to know the thread on the front of the body of it, that would be great. Last edited by sanddrag : 16-01-2006 at 05:12. |
Re: 3/4" bore x 1/2" stroke Bimba Cylinder model
i just modify the actuator from the KOP on www.firstcadlibrary.com, then just resize the actuator to the size i need it. If you want the lazy way to it, than i cant help you.
If you go to www.bimba.com and click on the CAD tab then choose your software, click "non repairable stainless steel cylinders", then click original line, select your bore size, then select your mounting option (for FIRST i believe you want the 04-DP, then plug in your stroke size and the model will generate itself for downloading.
Hope this helps. There is another website (aircylindersdirect.com) that has a similar cad generator but i would trust the bimba one more. Greg |
If you insert the i-CylinderBody model from the FirstCadLibrary into an assembly, a dialog box will pop up that asks you to pick the size of the cylinder you want. 3/4" x 1/2" is #1 in the table.
Important: Does anyone know what thread is on the front end of the body of the cylinder? Thanks so much. |
Check the Pneumatics Manual!
1/4''-28 for the shaft. 5/8''-18 for the body. |
| Same bore, same stroke, same mounting--is it legal? | Billfred | Pneumatics | 2 | 20-02-2005 00:41 |
| 24" Stroke 1.0625" Bore Piston Legality | Yan Wang | Pneumatics | 4 | 05-02-2005 09:32 |
| Need Inventor model 3/4" Bore Cylinder Quick | sanddrag | Inventor | 1 | 05-04-2004 00:40 |
| Stopping a Piston... | Dan 550 | Technical Discussion | 7 | 02-02-2002 11:36 |
