Go to Post We might not be as good as 217, or the other traditional "powerhouse" teams... but we are better because of them. Jason - dtengineering [more]
Unread 16-01-2006, 15:07
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Air gun length
Can we make our air gun longer than 38" ?
Thanks!
Unread 16-01-2006, 15:11
Re: Air gun length
Thanks!
Your shooting mechanism must stay within the starting footprint (28" by 38"). The manual is very good reading this time of year.
Unread 16-01-2006, 15:17
Re: Air gun length
Thanks, but I ment after the game starts, not at the first measurments.
Isnt there a 60" limit or something similar while playing?
Unread 16-01-2006, 15:18
Electrical Engineer
Rookie Year: 1995
Re: Air gun length
Thanks!
Max,
What makes you think that it is legal to make an airgun at all?
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 16-01-2006, 15:24
Re: Air gun length
Generally speaking about shooting mechanism, not air gun as a specific, sorry about misleading you.
Unread 16-01-2006, 15:27
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Air gun length
It must fit into the original space of 28x38x60. I suppose that if you put the gun at an angle in that virtual box, you could get a gun longer than 38", longer than 60" actually. But no, the gun cannot extend outside the original robot footprint, if thats what you mean.
-Sir Francis Bacon
-Albert Einstein
Unread 16-01-2006, 15:33
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Air gun length
Originally Posted by Andrew Blair
It must fit into the origninal space of 28x38x60.
And the reason is <S03>:
Originally Posted by <S03>
Shooter Mechanism must remain inside the ROBOT - Any mechanism used to throw balls must be contained within the original 28” x 38” x 60”starting envelope of the ROBOT and must be shielded such that the mechanism cannot make contact with other ROBOTs. A ROBOT that violates this rule will be considered unsafe per <S01>.
Unread 16-01-2006, 15:35
Re: Air gun length
Guys, I've copied this paragraph:
The_Robot.pdf
5.3.2.1: Robot Size
"<R08> Once a match begins, robots may extend horizontally beyond the 28-inch x 38-inch starting size under
their own power, up to a limit of 60 inches in either horizontal cardinal dimension. The robot may not exceed
the 60-inch height restriction at any time during the match. In other words, after the start of the match the
robot may expand up to a maximum volume of 60 inches by 60 inches by 60 inches. The one exception to the
height restriction is provided in Rule <R13>. Any restraints (elastic bands, springs, etc.) that are used to
maintain starting size must remain attached to the robot for the duration of the match."
Unread 16-01-2006, 15:42
Carpe diem
Re: Air gun length
Your cannon would be a part of your ball throwing mechanism. Therefore, your cannon can not exceed the 28" x 38" x 60" starting envelope. Please see this thread in the FIRST Q/A for further clarification.
Unread 16-01-2006, 15:45
Re: Air gun length
<S03> still wins. Your shooter (and barrel, as clarified by Q&A) must remain in the 28" by 38" footprint for the entire match. Length is only limited by what you can fit into the box at the start and cannot expand out of it.
Why does <S03> win here? 2 reasons: 1) It's a limiting agent on <R08>, and 2) It's a safety rule and will be heavily enforced.
Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance Ethulin Technical Discussion 39 14-01-2006 19:04
Higher PSI in air Tanks Projectchon Pneumatics 8 01-02-2005 15:05
More than two air tanks? Mercutio Pneumatics 6 10-02-2004 16:07
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
