Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 18-01-2006, 14:36
354.FIRST 354.FIRST is offline
FRC #0354
354.FIRST is an unknown quantity at this point
Angry Labview CMU Camera COM Port Help
Labview problem is with the COM port.
CMUcam2 v1.01 c7
Error Code: -1073807202
Error String: Property Node in VISA Configure Serial Port (Instr).vi->CMUcam2.vi->CMUcam2 GUI.vi
We have the camera set up using labview. Everything works fine.
We have a second computer where we are playing with the c code.
Labview works on first computer. Gives the above error on the second computer. First computer is a desktop, second is a laptop with a serial port.
HELP. We have read all the posts and tried what we could. No luck.
Thank you very much for your help
-Team 354
Unread 18-01-2006, 14:38
FRC #0354
Re: Notes on the camera
Oh ya,
Under the serial port menu in Labview, nothing is showing up. Just "refresh." nothing else and refresh doesn't help.
thanks
-354
Unread 18-01-2006, 14:40
FRC #0354
Re: Labview CMU Camera COM Port Help
We did read previous posts...
TTL Cable not connected, port baud settings are correct.
Unread 18-01-2006, 15:07
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
CMUcam2 v1.01 c7
-Team 354
Please post this in a new thread. Could a moderator split this?
Otherwise, I had that same problem and found out the serial cable wasn't in all the way.
http://www.mikesorrenti.com/
Unread 18-01-2006, 18:43
Joe Hershberger Joe Hershberger is offline
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
CMUcam2 v1.01 c7
-Team 354
You didn't install VISA on the second computer. Do so and it should work fine.
Good luck!
-Joe
