Go to Post I, for one, am perfect and therefore make no mistakes. (Unless you count all the times that I completely screw up) - Molten [more]
Unread 19-01-2006, 20:11
(InsrtNameHere)'s Avatar
(InsrtNameHere) (InsrtNameHere) is offline
AKA: Jason
FRC #0011 (MORT)
Team Role: Student
(InsrtNameHere) is an unknown quantity at this point
Gear Tooth Sensor Question
We here at Team 11 are having difficulties with the Tooth Gear Sensor. We are having trouble with the calibrations. It might be because of us not mounting it right, or something.
We are using a fisher price motor if it makes a differance.
Can someone help Thanks.
Unread 19-01-2006, 22:36
Jared Russell's Avatar
Taking a year (mostly) off
Re: Gear Tooth Sensor Question
http://www2.usfirst.org/2006comp/Spe...oth_Sensor.pdf
Make sure your sensor is oriented the way it appears in the pictures, and make sure the air gap is less than a few millimeters.
Unread 20-01-2006, 02:19
AKA: Dr. Brooks
no team (WRRF)
And you are trying to sense steel gear teeth, right?
The drive coupling on the fisher price is plastic.
Eugene
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
gears Michael Leicht Inventor 12 16-09-2004 10:52
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
