Go to Post If robotics is bad for you, well then I guess I'm gonna die. At least I'll die happy. - karinka13 [more]
Unread 20-01-2006, 16:35
Kevin Watson's Avatar
La Caņada High School
FRC #2429
PIC Signal to Robot Controller Pin Map
Did you ever wonder which PIC microcontroller signal was connected to each robot controller pin? Well, I got around to updating the document I made available for the 2004/2005 controller with the same information about the 2006 controller. You can find it here.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2006, 16:40
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: PIC Signal to Robot Controller Pin Map
-Kevin
Anyone else notice the 2nd I2C/SPI master on the relay ports? Noticed this a couple weeks/months ago, but haven't had time to play with it since then.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 20-01-2006, 18:32
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
This is perfect for my project.
Thank you.
VEX inputs Andrew Blair FIRST Tech Challenge 22 31-05-2006 18:17
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
[moderated]: A Challenge: YOU Rewrite G25 Tom Bottiglieri General Forum 10 30-03-2005 21:18
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
