IR Beam Troubles
Has anyone got the IR Photoswitch beams working? We tried wiring them up but got a .01V signal.
We do have it running on 12v power. |
Re: IR Beam Troubles
did u connect a pullup resistor ???
the output is o.c u know... |
Translation:
Did you connect a pull up resistor? The output is "open collector". "Open collector" means that it is essentially a contact closure to ground, not a logic-level voltage. It should work fine when connected to a digital input on the RC, because a contact closure to ground is exactly what the RC expects (it does provide pullups on its inputs). |
| Tilt Troubles | Mumford 406 | Programming | 4 | 29-03-2005 22:19 |
| Gyro Troubles | SteveO | Programming | 13 | 30-01-2005 16:46 |
| International Team Troubles | Jacqui Sutton | General Forum | 26 | 24-03-2004 07:37 |
| Maxi Block Troubles | MARobotics | Electrical | 3 | 27-01-2003 07:39 |
| Robot Controller & Operator Interface troubles | patrickrd | Technical Discussion | 10 | 25-10-2001 07:36 |
