Go to Post I don't need sleep, just more Mountain Dew. Oh, and a muffin. - hallk [more]
Unread 21-01-2006, 19:15
Andrew Blair's Avatar
FRC #0306 (CRT)
Odd MPLab error?
I've downloaded the student version of MPLab 7.20, C18 compiler, and have it all installed. I am trying to compile the default, unmodified version of the 2006 default code. When I make the file, I get the following message:
Error: Bad magic number in COFF file "D:frc_camera_2006camera.o".
BUILD FAILED: Sat Jan 21 19:05:26 2006
Whe I try to build the file, I get the following error:
D:frc_camera_2006user_routines_fast.c:58:Warning [2074] location PROD specified in the interrupt save list is redundant
D:frc_camera_2006user_routines_fast.c:58:Warning [2074] location .tmpdata specified in the interrupt save list is redundant
Executing: "D:MCC18binmplink.exe" /l"C:mcc18lib" "18f8722.lkr" "D:frc_camera_2006camera.o" "D:frc_camera_2006camera_menu.o" "D:frc_camera_2006eeprom.o" "D:frc_camera_2006ifi_startup.o" "D:frc_camera_2006ifi_utilities.o" "D:frc_camera_2006main.o" "D:frc_camera_2006serial_ports.o" "D:frc_camera_2006terminal.o" "D:frc_camera_2006tracking.o" "D:frc_camera_2006tracking_menu.o" "D:frc_camera_2006user_routines.o" "D:frc_camera_2006user_routines_fast.o" "D:frc_camera_2006FRC_library.lib" /o"camera.cof" /M"camera.map"
MPLINK 4.00, Linker
Copyright (c) 2005 Microchip Technology Inc.
Error - could not find file 'clib.lib'.
Errors	: 1
BUILD FAILED: Sat Jan 21 19:08:02 2006
Does anyone know what could be happening? Is my installation bad? My tools setup wrong? Or part of the workspace deleted, moved or corrupted? I'm at a loss.
-Sir Francis Bacon
-Albert Einstein
Unread 21-01-2006, 20:02
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: Odd MPLab error?
try reinstalling it again, 9/10 times the problems with things missing is an error during installion, install MPLab first then the compiler that is the order i always do it and there haven't been any errors yet(knock on wood)
KK4KQO
http://voltair.us
Unread 21-01-2006, 20:45
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
The bad magic number error is related to the COFF file structure changes between C18 version 2.x and version 3.x. You need the 2.4 version of C18 that comes in the KoP.
MPLab build error Derek t Programming 7 17-01-2005 09:33
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
MPlab error ryan_f Programming 9 24-05-2004 07:30
Error message in MPLAB IDE dddriveman Programming 11 18-03-2004 06:34
