Help with sonar sensor
How can i wire this to the 2006 RC?
http://www.edpcompany.com/pdf/Mini.pdf and will I be able to program it? as of now i'm guessing i should use PWM output to generate a signal and analog to receive the pinging how would i do that? |
Re: Help with sonar sensor
did you get the mini-a transducer?
we ordered a pair of those about a week ago, and they are supposed to come in tomorrow or Tuesday. as soon as i get a crack at them, I'll tell you what i can figure out until then, just remember ... don't wire them straight to the battery ![]() |
ours came in, and from what i've read, you have your ground and power pins, and then you have the TTL out put (like what the camera uses)
you would find the pin designations on your RC (the TTL port) and make a custom cable that brings your power and ground to an un used pwm port, and your input pins into the TTL port on the robot the downside to this ... no camera, because you only have one TTL port i'm still looking into this, and if i can find a way to hook this up using an analog or digital input instead, that would be great if you have any more questions or more specific questions specific to your model feel free to PM me good luck! rufus |
| Making a Sensor Board | SpaceOsc | Technical Discussion | 11 | 15-05-2004 12:46 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Banner Sensor Programming Problem | 2Crisis | Programming | 4 | 24-02-2004 13:40 |
| Translating pressure sensor readout into actual pressure | Mercutio | Pneumatics | 0 | 13-02-2004 16:29 |
| Quick Optical Sensor Question | zorro | Technical Discussion | 10 | 21-01-2003 06:39 |
