Go to Post At this rate, Team Update #2 should just eliminate the Minibots and replace it with the drive team captains playing rock-paper-scissors to determine the bonus points. - artdutra04 [more]
Unread 22-01-2006, 22:53
TTL Output on CMU Board
I see here there is a TTL port right on the CMU board.
Does anyone know why we get have to convert RS232 to TTL?
I have 2 theories, can anyone back these up with some facts?
A) The cmu board speaks RS232 natively, and the onboard conversion process is slower than the other converter chip (supplied to us by IFI)
B) It costs less to get 1200 RS232->TTL converter boards than 1200 4 pin female to female cables.
Unread 22-01-2006, 23:44
Re: TTL Output on CMU Board
Can you be more specific about where on the camera you found a TTL port described? The workbook you linked to doesn't seem to mention it.
Unread 23-01-2006, 00:21
Sorry about that. As Joel said, its in the diagram on page 17.
Unread 23-01-2006, 02:54
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
You can use it to talk directly to the RC without the TTL converter. See page 19 of the same manual. Just make sure you get the pinout right on the port.
Cheers!
-Joe
Unread 24-01-2006, 14:09
Cheers!
-Joe
Yeah, I thought you would be able to do that. Thanks for the cite.
But, I was wondering if anyone knew the direct reason for teams getting the TTL converter board and not just a straight patch cable?
Unread 24-01-2006, 18:35
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
As I understand the specifications on the camera, when using the TTL interface on the camera board itself, it's speed is limited to 9600bps. When using the serial adapter your speed is 115k bps. As far as I can tell, that is the only difference.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 22-01-2006, 23:47
Joel J's Avatar
Joel J Joel J is offline
do you..
I saw that also. It was on page 17.
Joel Johnson
RAGE (173) Alumni, 1999-2003
The *BIG* CMU Howto pi_guy578 Programming 17 21-12-2005 13:24
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
TTL -> RS-232 Board won't stay on! Mr. Lim Control System 5 16-02-2005 11:29
RS-232 TTL Board? Sidney San Martín Electrical 8 08-01-2005 22:46
