Go to Post FRC2010 - The flying purses :P - Bharat Nain [more]
Unread 23-01-2006, 15:06
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
CMU cam error 131. All serial tests passed.
I am getting error code 131 on my CMUcam. Every now and then the camera works normally but usually it just sits there with the red light on. All serial port tests passed. Does anyone have any idea what could be wrong?
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 24-01-2006, 14:24
Validius's Avatar
AKA: Mark Ratering
Re: CMU cam error 131. All serial tests passed.
anyone?
-Peggy Noonan
Unread 24-01-2006, 19:24
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I have no idea. I Googled "cmucam2 error code 131", and the first result was this ChiefDelphi thread. I'm not motivated to read the whole thread, but it might provide you a clue.
Unread 24-01-2006, 22:26
Validius's Avatar
AKA: Mark Ratering
Not really what i need. I'm tring to use the cam with the controller, not labview.
I think i will sent Kevin a PM about what code 131 actually means. Perhaps this could be remidied by using last year's camera though i would prefer not to.
-Peggy Noonan
Unread 25-01-2006, 08:56
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
To assist you in your quest....
Originally Posted by Jon236
in reference to my last email, I uncommented the debug line and got the following:
Camera: Inititialized abnormally with code 131
it then goes through states 1-3 and repeats
What's the secret message in the box?
Jon
It means that the software got tired of waiting for the camera to acknowledge receipt of its first command. In other words, the camera isn't communicating.
-Kevin
Have you got the TTL board connected in the controller correctly? Also note that it is somewhat loose, so a good connection may be difficult.
Jon mMittelman
Team236
Unread 25-01-2006, 09:15
Validius's Avatar
AKA: Mark Ratering
Jon
-Kevin
Jon mMittelman
Team236
Since the camera only works intermittantly it would make sense that somthing is loose. Is there a better way to ensure good contact with the TTL board?
-Peggy Noonan
Unread 25-01-2006, 09:43
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
If you wrap the cable around as they show in the manual, the cable will push on the little daughterboard a bit to help with the connection.
I've also found that intermittant camera functionality is often due to power issues, make sure your RC has a fresh backup battery on it.
Unread 25-01-2006, 10:41
Jon236's Avatar
AKA: Jon Mittelman
We're considering hot glue!
Unread 25-01-2006, 10:47
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
We use RTB (at least I think that's what it's called...). I saw some black rubber-y stuff on last year's controller, and when I asked that's what a teammate said it was. It looks like it would do a good job, but I can't vouch for it as I haven't used it before.
All I know is that electrical tape doesn't do it.
JBotAlan
EDIT: I see no reason not to use hot glue.
Aren't signatures a bit outdated?
Unread 05-02-2006, 11:32
scottish144's Avatar
scottish144 scottish144 is offline
AKA: Scott
FRC #0623 (Ohmies)
scottish144 is an unknown quantity at this point
I ran into this problem a few days ago. You need a charged backup battery.
Scott Haney
Programmer, Team 623
Vienna VA
CMU Cam prosseser running hot kjhobin Programming 4 10-01-2006 21:57
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
