Go to Post Read the manual! - Trent B [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 24-01-2006, 16:07
platt platt is offline
FRC #1345
platt is an unknown quantity at this point
Exclamation Vision Target Assembly
Did anyone build the vision target assembly according to specs, and if so where did you get parts/part #s?
Unread 24-01-2006, 16:15
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Vision Target Assembly
The pieces required to build it are included in this year's kit of parts, in the National Instruments box (if I am not mistaken).
Unread 24-01-2006, 16:24
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
The HDPE, and the green Cold Cathode Light kits were supplied, but the housing was not. From the FRC_Vision_Target_Sheets posted on the 2006 FRC Documentation page, it lists the housing as being a Hammond Aluminum Enclosure, 8"x16"x2".
We got two of these from Mouser:
http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid= 258397&e_categoryid=69&e_pcodeid=54605
The rest of the smaller items (terminal block,etc), we found equivalent parts in our surplus drawers.
Hope that helps
-Nate
Unread 24-01-2006, 18:14
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
we used 2x2 wood and made a frame, screwed the HDPE to it and glued the cathode tubes to the HDPE. Simple and cheap.
Kirk
Unread 26-01-2006, 17:34
keithv708's Avatar
keithv708 keithv708 is offline
AKA: Keith
FRC #1208 (The Metool Brigade)
keithv708 can only hope to improve
Send a message via AIM to keithv708 Send a message via MSN to keithv708 Send a message via Yahoo to keithv708
Thumbs up Re: Vision Target Assembly
a shoe box's?
Vision Target power supply AUWarEagle#1 Electrical 3 18-01-2006 22:17
Question concerning vision target Otrobotics General Forum 17 15-01-2006 15:59
Does the Vision Target seem rather dim? steven114 Technical Discussion 3 12-01-2006 21:19
Vision Target Chassis Mod? AnkurG Kit & Additional Hardware 1 08-01-2006 21:12
