Go to Post The programmers tend to get less credit than they deserve, but the robot wouldn't run if we weren't there. :) - IMDWalrus [more]
Unread 24-01-2006, 17:14
winners winners is offline
winners is an unknown quantity at this point
Kevin's Code?
I really wish to know what does Kevin's code (bells and whistles version) exactly do?
does it Track the green light or that it just returns/sends out some information for the CMUCam?
and if it tracks the green light, i wish to know were should I plug the servo PWM's to?
Thanks in advance.
Unread 24-01-2006, 17:26
Back after 4 years off
FRC #5279
Re: Kevin's Code?
KEvins code searches for light that falls within given parameters (the green light by default) and returns servo posistions to the robot controller. By default you should plug the Tilt servo int PWM 02 and the pan servo into PWM 01, You can read the Camera and tracking read me files included in his code for more information.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 24-01-2006, 18:02
Re: Kevin's Code?
Thanks very much for the help. but 1 more question, I loaded that code on the RC, so does it only return the servo values, or that it also tracks that color (keeps it in the middle of the frame captured by the cmucam)?
Thanks again.
Unread 24-01-2006, 18:55
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Kevin's Code?
If you do not have a window open, it will attempt to track the light, by default.
-Sir Francis Bacon
-Albert Einstein
Unread 27-01-2006, 15:55
Re: Kevin's Code?
what do you mean by a "window open"?
Unread 27-01-2006, 16:32
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Kevin's Code?
Thanks again.
Kevin's code reads the T-packet information coming from the camera and uses it to command the tilt and pan servos where to move the camera to position the "centroid" of the green light on the "center" pixels of the cameras detector. The center values are available/configurable in the tracking.h file along with many others. It is well worth your time to read through every comment and line of code he has written. All of this and much more are explained in the code.
I believe what Andrew meant by an open window is a terminal window. Kevin's code feeds back, using printf commands, information to a terminal window that can be opened in the IFI loader. It will allow you to see the positioning data. By looking through the terminal.c and .h files, you will be able to find what values are being sent to the servos to tell them how to position the camera. Extrapolating this information, you should be able to use it to position your robot and ball launcher to hit the target you desire.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Some things i'm trying to understand on Kevin's Accelerometer Code Squall Programming 2 03-02-2005 12:01
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
