Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 24-01-2006, 19:17
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Gyro Code Problems
I have done all the proper modifications to Kevins camera code. I added the adc code and the gyro code from Kevins site to his camera code. After I download the code the robot controller and the terminal window pops up it doesn't show that the gyro's bias is being detected. What's the problem? I'm very knew to programming.
Unread 24-01-2006, 20:16
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Gyro Code Problems
Originally Posted by railerobotics
I have done all the proper modifications to Kevins camera code. I added the adc code and the gyro code from Kevins site to his camera code. After I download the code the robot controller and the terminal window pops up it doesn't show that the gyro is being calibrated. What's the problem? I'm very knew to programming.
What is the state of the LEDs on the robot controller and the operator interface? (Your OI is powered, I hope. )
Unread 24-01-2006, 21:25
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Did you actually add the correct stuff to user_routines.c? I seem to remember having to do stuff that wasn't actually in the instructions..
Unread 24-01-2006, 22:40
FRC #0935
I did exactly what was in Kevin's instructions.
Sorry for being very new to programming
Unread 25-01-2006, 15:40
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Try downloading just the gyro code form Kevin and see if it works.
Look at the user_routines.c in the PURE gyro code.
Unread 26-01-2006, 09:30
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
i did that and i didn't get reasonable values
because i move the sensor 90 degrees and back where he was and i don't get the same values which i get i n the start
Unread 26-01-2006, 22:37
6600gt's Avatar
AKA: Lohit
I havent tried yet but I think the sensor gives you the change not the actual value.
Unread 27-01-2006, 10:45
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Remember that the gyro has a maximum turn rate that it can report. Turning faster than that (which is easy to do when holding the gyro in your hand) will cause signal overflows which translate into lower rotations report than actually occurred.
Try doing your test and turning the gyro VVVVEEEEERRRRRYYYYY SSSSSSLLLLLLLOOOOOOWWWWWWLLLLLLYYYYY and see what happens.
$0.02 from Lynn (D) - Team Voltage 386 Software
Unread 25-01-2006, 08:31
FRC #0935
Yes it is powered.
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Coding / Style Standards for sharing C code Joe Johnson Programming 33 01-05-2004 15:15
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
