Go to Post FIRST robotics: Not just for nerds. - Koko Ed [more]
Unread 24-01-2006, 23:54
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Is there a limit to how many balls we can pick up?
Our robot may be able to hold 40 balls. can we hog cheese and hold them to dump later?? Is there a limit?
Unread 24-01-2006, 23:58
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
Re: is there a limit to how much balls we can pick up.
you can hold as many as your robot is built to hold / as many as you can pick up off of the floor. i've heard a number of teams tossing this idea about as a strategy
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - 2016 : 573 Mech Warriors: Mentor
Unread 25-01-2006, 09:17
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
This can only be a strategy if you are able to steal the balls as your opponents put them back into play. If you are putting them into play, your opponent has already scored, and holding them doesn't increase your score. Any team that plans to "dump" during the final 10 - 15 seconds is going to find themselves being pummelled by the opposing alliance. It is significantly more advantageous to stop a robot from scoring 40 balls than it is to get onto the ramp for 25 points.
Think about what makes sense; if there are no balls to shoot on the field, what do you expect the opposing alliance to do? Twiddle their shooters? You better expect them to legally harass and block your robot at every move. You are making your robot THE prime target on the field. I hope you have a world-class pit crew!
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 25-01-2006, 20:55
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
Either that or a tank.
Unread 26-01-2006, 23:11
waialua359's Avatar
AKA: Glenn
thats what teammates are for? LOL!
If our alliance had the lead and all the balls are in our bins, it doesnt matter if other teams block us......wer'e still winning. at the end when teams go up the platform, they cant pin us at the same time on the other end of the field.
Unread 26-01-2006, 23:16
You aren't winning if you can't score those balls and the other alliance has more points.
They most certainly can pin you or block you from scoring at the end. It's worth not having the extra 15 points to block a potential 95 (robot on platform, assuming two others already on, + 80 balls in bin, assuming no shooter on your bot). No one says you have to go on the platform at any time in the match.
Unread 27-01-2006, 05:06
waialua359's Avatar
AKA: Glenn
Re: Is there a limit to how many balls we can pick up?
if an alliance is losing near the end of the match, say by less than 25 points, why spend your time blocking a team holding balls if you can overcome their score by loading your robot on the platform with your alliance mates. It at least gives your alliance a chance if no balls are available. Not doing anything to score is the worst move in that case.
As far as not having to go on the platform sometimes, it is obvious that this is true, but it has a much bigger impact this year than last year when all you got was 10 points max. 25 points is a difference maker in an evenly heated match.
I think the balls on the ground, however they end up there, will be far and few to come by if teams effectively dump balls in corner goals and can load their robots effectively with the human player. The missed shots on the center goal will probably be the most available.
The scenarios mentioned on this thread makes sense, but in every situation, depending on what's happening, it may call for a strategy of holding on to balls for a period of time.
Unread 24-01-2006, 23:59
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
No, there is no limit.
http://forums.usfirst.org/showthread...ght=ball+limit
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 25-01-2006, 08:30
Bill Moore's Avatar
Iv2gr8sons
AKA: Be More
Originally Posted by Ogre
Actually the limit is 80 balls. (Rule <G13>)
Stacked Balls above 60" limit? 1574aviad Rules/Strategy 8 19-01-2006 15:57
The awesome NON-INVITE FANTASY FIRST Draft Tim Delles Fantasy FIRST 73 29-04-2005 08:25
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
How many balls can you pick up?????????? CMC General Forum 6 14-02-2002 21:40
How do you pick up balls? Anton Abaya Technical Discussion 4 24-01-2002 15:03
