Go to Post What makes a man is not the mistakes, but the actions that follow. Andy B. - Andy Baker [more]
View Poll Results: What would you say is the best for lowering middle wheels?
1/32" 3 5.88%
1/16" 4 7.84%
3/32" 3 5.88%
1/8" 21 41.18%
3/16" 7 13.73%
1/4"!! 7 13.73%
Not lowering it 6 11.76%
Voters: 51. You may not vote on this poll
Unread 27-01-2006, 01:24
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
What is best for lowering the middle wheel?
I'm just wondering, what have other teams found to work best for lowering the middle wheel in relation to the other wheels in a 6WD system?
Unread 27-01-2006, 01:47
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: What is best for lowering the middle wheel?
1/8" does it for us. It makes our robot rock back and forth about a degree. I can live with that. One thing we had a problem with last year though... when we welded our chassis, it curved upwards, so our middle wheel was more like 1/4" lower. When you're welding your chassis (if its welded) make sure to evenly weld it, dont do one side and flip it over to do the other, or your frame will banana like our 2005 bot
Unread 27-01-2006, 08:00
occra 23.
AKA: ryo
None #1481
having a flexible frame helps keep all the tires on the ground somewhat.
so if you have a SOLID frame id go with 1/8 but bolted frames/more flexible frames id do 1/4
Unread 27-01-2006, 08:45
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
It really depends quite a bit on the type of tire treads you use. The softer and grippier (sp) your tires are, the more you need to lower the center wheel. We have found that with gum rubber Brecoflex belts, 1/8" was not enough.
Matt
Unread 27-01-2006, 09:04
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
A couple other things to consider is the amount your bot will sink into the carpet. Also the flex in the frame if it sags end to end. Last year I designed in a 1/4" but then got the bannana welding effect and it ended up being more like 1/2". Which actually turned out to be the magic number. I would say 1/4" is on the short side and a 1/2" max. Extra teeter is not a bad thing, but no teeter is a very bad thing.
www.179swampthing.org
Unread 27-01-2006, 09:57
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
I had this same question about our 6wd setup last year. I found that the offset distance varied, based on a couple factors. What tread you were using, how much "scrub" you wanted, how much "teeter" you could handle. In the end, it came down to the drivers feel for the robot. We used a series of 1/16" shims to fine tune the handling. We would go drive around until a battery died, then go back and add or remove a shim. When we found what worked best, we made a permanent shim and never touched it again.
Once it's built, play around with a couple different shim heights. You'll be amazed at the significant drivability changes, with such a small height different. Oh, and make sure this is done on a similar carpet to the playing field. Otherwise, all bets are off.
BEN
Unread 28-01-2006, 10:55
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Well according to the rules, you aren't allowed to score from any position than your starting one. If they're going to strictly enforce this, you are going to get penalties if you're going to rock on your middle wheel. Good luck with getting away with that though.
EDIT: Starting position meaning vertically, not the position of the bot on the field.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 28-01-2006, 11:23
FRC #0701 (RoboVikes)
can you post where you found this rule?
this would also cancel out turrets etc. seems wierd
Team 701
Unread 28-01-2006, 12:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I cannot understand what you're trying to say.
If you're saying that everything has to remain vertical--it does. Unless you do an absolutely terrible job of putting together your robot, and things are sliding up and down and back and forth, even if you rock maybe ~5* or something, everything on your robot still remains vertical with respect to the base of the robot. This is all that matters, as it would be illegal to climb the ramp if what you say is true.
And at any rate, I think you've entirely misinterpreted rule G17, as seen below.
<G17> ROBOT Orientation - ROBOTs must maintain their vertical orientation with respect to their starting
position throughout the match. ROBOTs may not intentionally tip over onto one of their initially vertical
sides and operate with this side parallel to the ground. If a ROBOT is accidentally or intentionally tipped
over onto its side, it cannot score any balls in any goals from this orientation.
It makes no mention of rocking back and forth, only falling over.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-01-2006, 12:49
Oh. Thanks for clearing that up. I hadn't read the rules in a while, but I remember that one, and I thought that you couldn't shift from your initail vertical position at all, even if it was just a little.
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Four wheel drive question haverfordfords General Forum 25 25-01-2005 23:24
Steering wheel issues jgannon Programming 5 15-12-2004 10:14
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
