*** CMUcam2 Frequently-Asked-Questions ***
I've started a CMUcam2 frequently-asked-questions document here: http://kevin.org/frc/camera. If you have questions that you think should be added to the document, please post them here.
-Kevin |
Re: CMUcam2 Frequently-Asked-Questions
Q3: Where do we plug in the pan and tilt servos?
A3: By default the pan servo is attached to the robot controller's PWM 1 output and the tilt servo is plugged into the the robot controller's PWM 2 output. These assignments can be changed in camera.h. Don't you mean "tracking.h" ? |
-Kevin |
what is the difference in using the PWM outputs and the Servo0, 1 on the camera?
-Kevin |
The CMUcam2 Frequently-Asked-Questions document has been substantially updated in the last day or so. Included is a troubleshooting checklist. It can be found here: http://kevin.org/frc/camera.
-Kevin |
#7
In the thread titled "Code Errors with Bells and Whistles" I detailed a problem I encountered when I rewrote part of your code so the camera scans in both directions. Since you wrote the origanal, i was wondering if I possibly just left out a neccassary intailization line or something. Can you give any suggestions?
#8
-Kevin |
#9
Ok, I e-mail it to you if it doesn't work. I made a couple changes. One things was to move the intailization to the very top of the code. Before, I was calling Tracking_Config_Data info before intailization, so that might have been the problem. If it was I'll post here to let you know that it was fixed. Otherwise I should have it sent by five tonight. Thanks for the help. |
#10
Can you use a different motor to control pan function? if so what would the code have to look like?
#11
. First, the motor does not have PWM versus Angle, thus you'd have to find some method of finding how to fix it so that it did, then you'd have to figure out how you want to keep track of what angle it is at. Basically it is complicated. |
#12
We ended up using the pan servo to pan the camera, then use the data to the pan servo to run a motor that steers our turret. In effect, the turret motor keeps the camera steered to the target. When the pan servo is looking straight ahead, the turret motor stops. When the pan servo is off-center, the turret motor turns the whole business in the required direction to get pan servo looking straight ahead. If the tracker is searching rather than tracking, we disable the turret motor until the tracker acquires the target. You can test if the tracker has acquired the target by examining T_Packet_Data.my. Zero signifies searching; nonzero signifies tracking.
how do you re-upload the tracking.h file to the camera again after modifying it? thankss -bunch of freshman noobs from clovis, CA team 1671 |
#14
1) I was trying to drive the robot and operate the camera at the same time so I enabled "Default_Routine" in the Process_Data_From_Master_uP function but I think it conflicted with the camera code (i'm not sure if that's right) because the camera wouldn't work at all. So I just put whatever I needed before "putdata" [the pwms, relays, etc.]
i don't know if my assumptions were right or if i messed up but i think you should address this in some form of a question (that I obviously can't come up with right now). 2) This is a stupid mistake, but someone else might have done it before. If you "accidentally" switch the servos hooked up to the RC, you get that "searching searching searching" thing also and it took me an hour to figure that one out (it's always gotta be the simple things that take forever to figure out). 3) I think you should put something at the top or inside the code about being careful when you load the code for the first time. I had the pwms hooked up to the camera and my motors hooked up to pwm01 and pwm02. So, as the camera tracked the green light, the robot went crazy and i nearly killed myself. After reading the FAQs, I figured out why but maybe if there's a warning somewhere inside the code, it won't happen to another team. 4) When i started using the camera for the first few times, i had the serial cable hooked up to the camera along with the pwm to the ttl port. It's obvious to me now that I can't have both hooked up to the camera at the same time but it wasn't then. You could put that in your FAQs ....those are all the mistakes i can remember but i'm sure i have plenty more to come. =) btw, after my series of errors, my camera worked wonderfully. you're the man kevin. my whole team's amazed how "i got" the camera to dance around but really, it was all your hard work and i got the credit for it. great job. oh, and the FAQs helped a lot! Last edited by nehalita : 08-02-2006 at 19:16. |
#15
Kevin We Need Your Help Re-Uploading the tracking.h file Anyone!?!?!? |
| Questions you've been asked about robotics | JamizzleHavok13 | Chit-Chat | 32 | 09-08-2009 16:16 |
| #1 The Journey of a FIRST Graduate: Questions | Ken Leung | General Forum | 12 | 27-07-2005 18:24 |
| Please post questions Chairman's judges asked!! | Roxanna V | Chairman's Award | 0 | 05-04-2005 10:33 |
| Q/A questions so far.. | AmyPrib | Rules/Strategy | 49 | 28-01-2005 08:39 |
| **FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information | Rich Wong | FIRST E-Mail Blast Archive | 0 | 07-12-2004 17:22 |
