relay fwd & rev
What is the difference between the fwd and rev on the relays? I have heard that it can be used such that only one spike is needed to acuate a piston. How would we program so we could use one spike?
Re: relay fwd & rev
I think what we did is hook up one side (red wire) of the solenoid to the M+ and the other to the M- then hook up both black wires to ground directly
hope it helps |
| Controlling Solenoids With Victors | Brandon_Cmpvir | Electrical | 20 | 16-03-2004 10:21 |
| Default mapping relay questions | Jared Stofflett | Programming | 1 | 25-02-2004 19:06 |
| Relay Aliases Backwards | Jeff Zampieron | Programming | 19 | 18-02-2004 16:27 |
| Drill Motor Output - Fwd vs Rev | archiver | 2000 | 1 | 23-06-2002 22:56 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
