Go to Post College was the best twenty years of my life. - Richard Wallace [more]
Unread 30-01-2006, 22:12
BillyJ BillyJ is offline
BillyJ is an unknown quantity at this point
Dashboard Port - Hyperterminal?
I'm trying to create my own dashboard program, so I figured the first step would be to make sure everything is as I expect by checking it in Hyperterminal.
I use the info in the dashboard_spec file from IFI, but try as I might, I can't get it to display anything other than non-characters (a bunch of wierd symbols).
Somewhere here I read that 19200 wasn't the correct rate, but even changing that to the suggested one wouldn't work.
How should I go about doing this?
Thanks
Unread 30-01-2006, 22:16
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Dashboard Port - Hyperterminal?
Thanks
19200 shold be the correct rate. The dashboard works by sending the ASCII characters for the numbers, e.g. 176 would be sent as "°", not "176".
If you don't want to mess around with the low-level stuff, Sean Witte has a programmable dashboard wrapper at http://www.chiefdelphi.com/forums/pa...le&paperid=593
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 30-01-2006, 22:26
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I've got a C program that will accept a config file, and write stuff like
pwm01=127
pwm03=255
ub1=230
to a file.. It's about as close to raw access you can get. I'm not sure how close everything in it works (infact, I suspect everything is off by two), but it might be a good starting point.. Let me know if you want it
Unread 30-01-2006, 22:32
That makes so much sense now that I think about it. Let me play around with it and see where I can get. Thanks
Unread 31-01-2006, 15:39
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
did you forget about LabVIEW?
the application that was supplied this year is exactly what i was trying to get our team to create for the last 3 years.
it provides a beautiful display of data. the display includes graphing and other display types.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Dashboard port question patTeam241 Programming 5 16-02-2005 02:23
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
