Go to Post Cut out the ridiculous vitriol. It's tiresome. Be productive. - Lil' Lavery [more]
Unread 30-01-2006, 22:39
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Optimal Tracking settings
The default settings were giving me a little bit of trouble. I raised the allowable_error and gain_values, and it seemed to significantly help the problem. Would anybody care to comment on what settings you are using, if you have tested it on the moving robot, or just "on the bench", and how well those settings are working for you?
Unread 30-01-2006, 22:56
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: Optimal Tracking settings
I have lowered the search delay to 2 and rewritten the search code to use a different search pattern. I have also tweaked the min and max pwm tilt and pan values. I also changed the default step size so that the camera only tilts up twice. In addition I reduced the allowable error to 2. After these changes it locks on to the target in less than a second and never looses the target even while moving, so long as the light is still within its range of motion. Since my error settings are low the camera does twitch when stationary but I believe it will not be a major problem. What type of problems are you having with the default settings?
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 31-01-2006, 11:38
bush's Avatar
AKA: Aaron
significant oscillations in the y-axis with a still camera and target
>Edit: Increasing gain values helped somewhat
Problems with tracking Shinsa Programming 2 07-02-2010 14:35
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
'tracking' flag zdeswarte Programming 3 20-02-2005 13:53
HELP! My 'Documents & Settings' Folder Is Gone... WITH ALL MY STUFF! Joe Matt Chit-Chat 3 28-10-2004 21:09
trouble with beacon tracking code [53] opticruzer Programming 9 27-01-2004 12:19
