Go to Post What if my teams drive train isn't an option? - MARS_James [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 31-01-2006, 08:54
Bruce Barber Bruce Barber is offline
FLL #1320
Bruce Barber is an unknown quantity at this point
Load config from file
On the labview software, using the CMUcam2Gui we are having a problem getting a drop down menu from the load config from file. Can you please help us and let us know what we are doing wrong?
Thanks,
Bruce Barber
Unread 31-01-2006, 09:46
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Load config from file
Part of your problem is that there is no drop-down menu from the "Load Config from File" button. Remember that you actually have to "run" the program, by pressing the run button or pressing CTRL-R. Once your program is running, you can press the buttons and expect a result.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Battery Life, 50A load discharge test method/results Dale(294engr] Electrical 5 22-01-2006 09:14
.hex file too large for 2004 controller? AL_E Programming 6 21-01-2006 22:54
C HELP PLEASE sglegend11 Programming 4 14-11-2005 21:35
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
