Go to Post I think that is important to note that winning teams have won without bending the rules. GP allows you to go ask, investigate and take pictures. Learn from others when you have the chance. - Al Skierkiewicz [more]
Unread 31-01-2006, 22:36
Calvin_1631's Avatar
Calvin_1631 Calvin_1631 is offline
AKA: Calvin
FRC #1631 (Cybernetic Cougars)
Team Role: Electrical
Calvin_1631 is an unknown quantity at this point
Camera focus
we have our camera mount all done and we had code and it worked fine. We took a sanp shot and it was very clear. But when we put it away and got it out the next day our focus was messed up. we took a screenshot and it was really blurry. we have tried to get it clear but we cant. how can we do this without turning it 1/2 way left or right to focus. also our camera can find and track the light within 3-4 feet. when we get out of that range the camera can't find the light. do we first have to refocus before we can track the light farther away?
Unread 31-01-2006, 22:47
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Re: Camera focus
You should only need to focus it one time. When you focus it, everything except objects within a few feet should be pretty clear. After it's focussed, don't turn the lens anymore and then you should be all set.
Unread 31-01-2006, 23:11
Steve Orr's Avatar
Steve Orr Steve Orr is offline
iusorr
FRC #1293 (D5Robotics)
Steve Orr is an unknown quantity at this point
Send a message via AIM to Steve Orr Send a message via Yahoo to Steve Orr
Re: Camera focus
I know last year some teams suggested wrapping teflon tape (used in plumbing) around the lens several times to help keep it in position once the focus was achieved... (just a thought).
S.Orr
D5Robotics : Team 1293
Irmo, SC
Unread 01-02-2006, 00:20
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
Re: Camera focus
for tracking the light, you need to use LabView GUI to reconfigure it a bit more
Unread 14-02-2006, 10:09
Mike223 Mike223 is offline
None #0223
Mike223 is an unknown quantity at this point
Re: Camera focus
My Team has been having a similar problem with the camera. It can track the light within a certain distance but once you move farther away it stops. Do we need to refocus the camera or could this be a problem with the code? Any help or advice would be greatly appreciated.
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
