Go to Post I've found that housework is more fun with power tools. - RogerR [more]
Unread 01-02-2006, 00:15
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
How do you mount the encoders to the Gear boxes?
I have not found any documentation about how to mount the encoders to the gear boxes. Does anyone have any suggestions or info about this?
Waialua Robotics
Unread 01-02-2006, 00:24
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: How do you mount the encoders to the Gear boxes?
Ours has threads and a nut just before the shaft, so we drilled a hole a certain distance from one of the gearbox shafts allowing a plastic gear on the encoder to mesh with a brass gear on te shaft. Your encoders could be different so i dont know if i'm being much help.
Unread 01-02-2006, 02:49
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Waialua Robotics
We use a hollow shaft encoder from US Digital. I make the output shaft of the transmission a bit longer and mount the body of the encoder to the side of the transmission. The encoder disk slips on the shaft and is held in place with a set screw.
Unread 01-02-2006, 14:35
Jared Russell's Avatar
Taking a year (mostly) off
We actually put a small spur gear on the encoder and have it spinning as a dummy on our gearbox. Works great.
Unread 01-02-2006, 17:19
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
There are some pictures in the manual and on the IFI site.
Try it out...it's relatively self explanatory.
Unread 01-02-2006, 21:07
Pat234's Avatar
Pat234 Pat234 is offline
None #0234 (www.cyberblue234.com)
Team Role: Human Player
Pat234 will become famous soon enoughPat234 will become famous soon enough
Last year 234 took the output shaft down outside of the drive gearbox to the diameter of the encoder and then attatched heat shrink tubing between the two shafts to relieve stresses on the encoder. This worked quite well, but we ended up not using becuase we didn't drive last year in autonomous.
Life is a trip the best way to get started is shut your mouth and keep walking. -Anonymous
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
gear boxes BoticsPUNK General Forum 6 24-01-2003 20:35
FISHER PRICE GEAR BOXES archiver 1999 2 23-06-2002 22:07
the motor mount with gear switch newatthis General Forum 4 15-01-2002 22:07
