Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 01-02-2006, 08:29
koenig3456 koenig3456 is offline
Programming Coach
None #0681 (EARTH Squad)
koenig3456 is an unknown quantity at this point
Question Accessing serial ports
I'm trying to use the ReadSerialPortOne() function from EasyC.
The mplink linker can't find the definition of symbol ReadSerialPortOne.
Where is the object or library file that defines ReadSerialPortOne?
Unread 02-02-2006, 07:57
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Accessing serial ports
Whoops!
In the last blitz of getting WPILib wrapped up, I forgot that those functions were documented and changed their declarations to:
unsigned char _ReadSerialPortOne(void);
unsigned char _ReadSerialPortTwo(void);
void WriteSerialPortOne(void);
void WriteSerialPortTwo(void);
So those functions are available, and I should probably change the names do match the documentation. This was during a binge where I was making all the functions not used outside of the library to not conflict with functions that users might write by prepending them with underscores.
If you want to use them, go with the underscored (_) version for now, and I'll try to make a new version later that has them corrected, with the include files fixed as well.
Please let me know if they work for you. Also, beware, that the camera code uses serial port 2 exclusively.
Brad Miller
Robotics Resource Center
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
Where can we get PS2 type game controllers with serial ports? waialua359 Control System 12 25-01-2006 22:33
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
