Go to Post You can't please all the people all the time. The rationale of "lots of people don't like it" is not a reason to stop doing it. - Karthik [more]
Unread 01-02-2006, 12:54
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
pic: Team Rush 27 - Shooter Concept
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 01-02-2006, 12:55
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: pic: Team Rush 27 - Shooter Concept
Ooh.. So pretty.
Is this a stationary attachment, or is it turning, and if so how many times?
If so, where are the wires headed?
Great CAD so far. Hope to see it soon.
Unread 01-02-2006, 13:02
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
Its seems to be made to turn. You can see a globe motor mounted upside down to the left. I think they were just to lazy to actually make the sprocket and at the moment there is just a solid ring.
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 01-02-2006, 15:52
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
Whoever designed that, has skill.
Unread 01-02-2006, 16:30
occra 23.
AKA: ryo
None #1481
meh. they downloaded stuff. slackers
but wow. detail. with we had the resources to pull sumthing like that off.
if you dont connect the pitching of the 2 sides, then you can control more aspects of the ball.
launch angle, direction are obviously doable, and by changing the rotation speeds of either side will change the spin sideways, and by haveing a different launch angle with right and left you'll have a sorta rifling rotatioin too. fun!!
Unread 01-02-2006, 13:04
AKA: Anthony Lapp
pictures of the turret have already surfaced.......so yes it spins.
it spins as much as we want it to, though i doubt it would ever travel more than 180 degrees. this turret is for precision movement....it mimicks the camera gimble.
as for wires, i can't say. we've managed to build a turret for the last 5 years....wires have never been a "go," "no go," item.......they will most likely run around the back of the device and be placed inside some slick looking wire loom. leave plenty of slack...and bam!, your wired.
i'll let the electric knobs work on that.
not too lazy......
there is no sprocket involved. see either picture already posted. it is a 129 tooth, 12DP, 20 degree PA spur gear.
that is hard to draw! not to mention frivolous. keep in mind the title of the pic..."concept." this implies that you aren't seeing a completed drawing.
Anthony Lapp
RobotOpen
Unread 01-02-2006, 13:09
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I've been curious to see what some other folks do to 'shield' their mechanisms as per the rules. Do you plan to cover the wheels more than what is shown or do you feel that the standoffs are adequate?
--Madison--
...down at the Ozdust!
Unread 01-02-2006, 13:24
AKA: Anthony Lapp
i think the standoffs are adequate. it is a tough call though.....
as designed there is plenty of room to insert a finger and have it severely mangled. but there is enough room to keep from having the finger wedged. for now the standoffs stay.
there are also other mechanisms near or around the shooter.....these may ultimately provide enough protection from the shooter wheel.
Anthony Lapp
RobotOpen
Unread 01-02-2006, 13:32
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
so, how do the balls go from your other pictures to be put within the wheels to shoot towards the goal? the force of pushing them upwards allows them to get sucked in with in your shooter and there it goes?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Seems like it would be safer without the standoffs. I'm thinking the standoffs would help the wheel suck your fingers in, instead of keeping them out. Full shield or no shield is what I say.
Unread 01-02-2006, 13:38
AKA: Anthony Lapp
the balls simply transfer from the ball elevator, through the turret and into the shooter. you can't see from these pics, but the design allows for the lift rollers to get extremely close to the underside of the turret.......balls pop up through the bottom and fly away.
the design was executed in such a way that the location of the turret and the elevation of the gun don't change the loading location.
Anthony Lapp
RobotOpen
Unread 01-02-2006, 14:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I want me one of those!
...........or two
Unread 01-02-2006, 17:37
Using what software?
I can crank that out in about 10-15 minutes in SolidWorks.
But then again, I have been using it for at least 3-4 years now.
Unread 01-02-2006, 18:52
President, VEX Robotics, Inc.
Elgin,
I have a new found respect for you now that I know you use SolidWorks.
I have been using it since 1997 and the ThunderChickens have been using it since 2001.
Anthony,
Nice shooter. I'm not a big fan of the side by side, but you guys looked like you have a good design. BTW, I agree with Elgin, it is pretty easy to draw gears in SW, but it is definitely unnecessary.
-Paul
Unread 01-02-2006, 18:55
Thanks Paul.
Yeah, basically to make it from scratch in solidworks, I would draw one tooth, and rotate however many times.
Nowadays, gear manufacturers have all CAD drawings in easily converted formats for your applications that you could just drag and drop in.
We customized a gear just the other day from the firstcadlibrary by extruding cuts and what not, and it was pretty straight forward.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
pic: Team Rush 27 - Up and out! ajlapp Robot Showcase 17 08-02-2006 18:39
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
pic: Team RUSH 27 Electrical Box austind27 Extra Discussion 20 02-03-2005 19:41
pic: Team Rush 27 - Full Bot Inventor ajlapp Robot Showcase 7 19-02-2005 14:05
