Go to Post I found another student once at a Cross Country meet because she was wearing a team shirt. I must say, I was surprised. I should start wearing my team shirt around more often. - TheBoulderite [more]
Unread 01-02-2006, 15:55
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question What does this I/O Message means?
Searching...
Searching...
all of a sudden I lost patience ang got mad. So i thought that the default colour values are not working therefore i chose to calibrate it and use my own colour values.
Red: min 56, max 106
Green: min 215, max 255
Blue: min 201, max 251
Than i brought the lights close in front of cam and i see the below message:
Pan angle (Degrees) = -20
Titl angle (Degrees) = 5
Pan error (Pixels) = 43
Tilt error (Pixels) = 82
Blob Size = 1
Confidence = 14
What does this message means and what should my next step be?
Unread 01-02-2006, 16:37
steveg's Avatar
steveg steveg is offline
Livin' the Dream
AKA: Stephen Guerrera
steveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to beholdsteveg is a splendid one to behold
Send a message via AIM to steveg
Re: What does this I/O Message means?
Searching...
The camera is looking for the green target but hasn't found it yet
The Block of text reports the following information:
1. Pan Angle (degrees):
• The position of the Pan Servo relative to center (127) represented in
degrees.
2. Tilt Angle (degrees):
• The position of the Tilt Servo relative to center (127) represented in
degrees.
3. Pan Error (Pixels):
• How far off (in Pixels) from the vertical center of the color blob the sensor
is aimed.
4. Tilt Error (Pixels):
• How far off (in Pixels) from the horizontal center of the color blob the
sensor is aimed.
5. Blob Size (Pixels):
• The size of the color blob (in Pixels) reported from the Sensor.
6. Confidence:
• The (# of pixels being tracked / area of the bounded rectangle)*256 and
capped at 255.
...Find all this and more at http://kevin.org/frc/CMUcam2_workbook.pdf
The first thing that would concern me is how high your error numbers are and how small your blob size is. If you haven't modified the code, it should move to where the target is once it aquires it and the error size should go down to something within the defined acceptable error. I don't remember what the default values are off the top of my head, something on the order of 5 pixels or so. If it doesn't home in on the center of the target, check the code in tracking.c.
How far away from the target are you?
Also, I don't think that you should need to change the color values from the default ones that Kevin gave you. They seem to work all right in most cases and most light. We've tried it in varying conditions, from all the lights off, to sunlight, and there was very little variation in tracking conditions (bright natural light seemed the worst).
Unread 10-02-2006, 21:33
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Originally Posted by steveg
6. Confidence:
capped at 255.
I searched that document and the forums. Which "bounded rectangle"? The target blob? The camera sensor?
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 10-02-2006, 21:37
Andrew Blair's Avatar
FRC #0306 (CRT)
This is the smallest rectangle that will fit around the color blob. By dividing the area by the # od pixels contained, you can find the pixel density, or "confidence" of the track.
-Sir Francis Bacon
-Albert Einstein
Unread 10-02-2006, 22:36
FRC #0957 (WATSON)
Thanks.
Addressing I/O in Sections astro1652 Programming 7 18-09-2005 19:28
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
message too short error Melissa Nute CD Forum Support 7 03-06-2004 00:02
what is said, and what it really means. Da Moose! Chit-Chat 4 13-01-2003 01:05
