Go to Post An inability to communicate your ideas effectively is a handicap you would be well served to strive to overcome. - Ether [more]
Unread 01-02-2006, 16:12
akedomakona's Avatar
akedomakona akedomakona is offline
Jason Cohen, President Team 168
FRC #0168 (The Flashbacks)
akedomakona is an unknown quantity at this point
Send a message via AIM to akedomakona
Exclamation can we use a xbox controller? (was: help)
would it be legal to use a xbox control as are robot controller???
Unread 01-02-2006, 16:28
Ethulin Ethulin is offline
Too many hats to count
AKA: Erik Thulin
FRC #0492 (Titan Robotics)
Ethulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud ofEthulin has much to be proud of
Send a message via AIM to Ethulin
Re: can we use a xbox controller? (was: help)
Well you ask a different question in your tittle as in your content.
Yes.
Probably not. The operator interface only takes 15pin game port connectors, so you would need to do some wicked conversion.
2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's
Stamp Scouting || Titan Robotics
Unread 01-02-2006, 16:35
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
as long as you know (or can figure out) what pins you are soldering on the actual controller it should be pretty easy, but if you are trying to convert the existing pinout to the 15 pin port (like the PS2 whitepaper) conversion I would imagine that would be much more difficult.
Unread 01-02-2006, 16:41
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
an xbox connector is just a glorified usb connector. if you tap into regular usb connector, you can then get a usb-15pin connector.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 01-02-2006, 19:03
Umm Errr...
Your right about the USB port. The controller ports on the XB are USB ports with a different connector. When MS released the XB they didn't want it to seem too much like a PC and they felt USB ports are a PC thing, so they changed the connector to disguise things. As far as converting it to a 15 pin gameport, this is not so simple as just spicing some wires together with the proper connectors. At the very least, you need a power supply of some sort, a microcontroller, a USB host controller, some digital potentiometers
, and lots of software. See: this team built a playstation controller converter With an XBOX things are alot more complicated than the playstation.
Btw this has already been discussed. I think i am going to get really irritated if someone asks this question again:
http://www.chiefdelphi.com/forums/sh...ad.php?t=31057
http://www.chiefdelphi.com/forums/sh...ad.php?t=22883
http://www.chiefdelphi.com/forums/sh...ad.php?t=42732
http://www.chiefdelphi.com/forums/sh...ad.php?t=42690
1139 Alumni
Unread 01-02-2006, 21:37
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
The orginal plan was a game cube controller - but I was told that would have been MUCH harder. Same with the Xbox controller (I was told...).
Brian Graham
Unread 01-02-2006, 22:00
rarprrydude234's Avatar
rarprrydude234 rarprrydude234 is offline
234 Alumni, 234 Mentor
AKA: Alan
FRC #0234 (Cyber Blue)
rarprrydude234 is an unknown quantity at this point
i am pretty sure that if you would use an xbox 360 wired controller with the usb connector that you can purchase a small conversion adapter made for computer parts that will work with usb to 15 pin connectors. check on newegg.com and outpost.com and also maybe tigerdirect.com if not at any of these places then it will prolly not be found at all. and sry if not
Unread 01-02-2006, 22:17
groves groves is offline
Steve Liggett
None #1213 (Groves)
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
we just open the ps2 or xbox controller and de-solder all of the wires and then take the controls that they give us and solder the wires to the pots and buttons. it really isn't that difficult however you will need to know your way around a soldering iron and a multimeter.
http://www.chiefdelphi.com/forums/sh...ghlight=groves
Unread 01-02-2006, 22:21
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
For what it's worth, the wired XBox 360 controllers use a standard USB connector. That'd make your job a bit easier, at least.
--Madison--
...down at the Ozdust!
Unread 01-02-2006, 22:29
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Pretty much to use an Xbox controller hooked to the OI you will have to open the xbox controller, gut it and then mod it completely into an analog device. Its been tried and usually turns out looking poorly as there is not much room in those for new hardware and mounting equipment.
Good luck!
-Michael Dessingue
Unread 01-02-2006, 22:40
stinger's Avatar
stinger stinger is offline
The laziest animator ever!!!!
AKA: wouldn't you like to know;)
Team Role: Animator
stinger is an unknown quantity at this point
At compatition i saw a control board made completely of a modified PS2, as for the controller i have no clue. so i couldn't be more help
There is a method to my madness..I just don't know what it is...then again if I did know then I wouldn't be mad now would I?!?!
Avatar by VG Cats
XBOX CASE MOD HELP! Chris Reynolds Chit-Chat 4 27-11-2005 20:03
Mini-Me robot arm controller Andrew Schuetze Control System 7 19-10-2005 11:07
Missing Xbox controller from San Diego lock-in... chaoticprout Off-Season Events 0 22-05-2005 20:38
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
