pic: Belt drive 1559
Re: pic: Belt drive 1559
looks easy to adjust the tension. nice.
does that belt have teeth on both sides? |
Yes it does
They are small though so that may need to be looked at
Shooter or lifter?
This is the lifter. I'm intending on posting the shooter later in the week.
#7
Looks heavy.
Is 25-30 lbs about right?? |
#8
Yea it is rather heavy. We are planning to drill holes throughout the frame to decrease the weight. Even after it may be heavy. The bright side is, the material is extremely strong.
#9
its not all that heavy. with the motor it comes to 18 lbs. The material, minitek is indestructable. its strength to weight ratio is incredible.
| Direct Drive Four Motor System | Collin Fultz | Technical Discussion | 42 | 02-11-2006 12:03 |
| Drive belt | Rachika Garcia | Rules/Strategy | 3 | 10-01-2006 21:19 |
| What teams have used belt drive on previous robots? | Alex Cormier | Technical Discussion | 10 | 06-11-2004 09:08 |
| pic: Drive System | CD47-Bot | Robot Showcase | 3 | 27-02-2003 14:11 |
| pic: Team 870 Rear Drive Train | CD47-Bot | Robot Showcase | 2 | 27-02-2003 00:22 |
