Go to Post Limits are imposed by both man and nature. Understanding those limits and attempting to push past them is the basis of creativity. - Dave.Norton [more]
Unread 01-02-2006, 20:42
gumbyman-829's Avatar
gumbyman-829 gumbyman-829 is offline
AKA: ガムビ(gumby)
FRC #0829 (N/A)
Team Role: Electrical
gumbyman-829 is an unknown quantity at this point
Send a message via AIM to gumbyman-829 Send a message via Yahoo to gumbyman-829
Question Placement of the SLU-35 Terminal Lugs
Besides on the batteries, where else should the SLU-35 Terminal Lugs be connected?
ガムビ(Gumby)
Unread 01-02-2006, 20:54
Sara Milton Sara Milton is offline
AKA: Smilt
FRC #0237 (T.R.I.B.E)
Sara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant future
Send a message via AIM to Sara Milton
Re: Placement of the SLU-35 Terminal Lugs
Circuit breaker panel (20/30amp)
Unread 02-02-2006, 08:12
These lugs are meant to be used on all primary wiring, i.e. #6 wire from battery to fuse blocks. That includes the 120 amp main breaker. If you are using the small panels, then they must be used for the positive and negative connections to those panels and the wire that feeds the negative terminal of the battery to the ground stud.
Unread 02-02-2006, 08:27
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
But, if I'm understanding the rules correct, unlike last year, we aren't required to use the SLU-35 lugs if we properly connect alternative and proper connectors to the #6 wires.
From the Q&A forum:
http://forums.usfirst.org/showthread.php?t=296
I was hoping for some clarification on a rule in the manual. In section 5.3.5 Electrical System Rules, part of rule <R54> reads:
“The [Battery] connector must be attached with either the copper SLU-35 lugs provided in the Terminal Supply Bag or appropriate crimp-on lug connectors” (pg16).
To clarify the rule, is a terminal like the attached image acceptable to use when it is, “first lightly crimped on the wire and then soldered,” (2006 FIRST Guidelines, Tips, & Good Practices, Rev A; Page 15; last paragraph) with a quality solder connection per the recommendations of the Society of Automotive Engineers specifications, or is it imperative that we use the solder-less lugs given to us in the kit?
GDC GDC is offline
Senior Member
Default Re: Clarification on SLU-35 Lugs
The terminal you suggest is an appropriate crimp-on lug connector.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 02-02-2006, 09:03
From the Q&A forum:
Yes you are correct, and the description applies to those connectors as well. The original question was specifically about the SLU 35 use.
Unread 02-02-2006, 10:21
Don Wright's Avatar
FRC #0469
Thanks Al. I was just verifying my understanding without asking the question.
Off topic...is 111 coming to either the Detroit or Great Lakes regional?
Product Manager
Unread 02-02-2006, 10:42
No, Unfortunately, I like GLR a lot.
We are sort of the host for Midwest and will be attending Milwaukee also. A lot of rookies at both events. A lot of new faces to meet.
Unread 02-02-2006, 11:07
Don Wright's Avatar
FRC #0469
Good luck and see you in Atlanta!
Product Manager
Unread 03-02-2006, 00:57
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Also remember if your using a solder on connector on the 6 gauge wire use an iron that can get it hot enough. Most common PCB/electronics irons wont putout enough heat to make a good secure connection!
SLU-35 Terminal Lugs Mr.D Electrical 2 23-01-2006 10:49
SLU-70 Lugs Daniel Electrical 46 03-05-2005 08:31
New LED Lights this Year, spec for placement? Chris_Elston General Forum 12 16-02-2004 17:32
