Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 02-02-2006, 09:32
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Strange but...need fresh eyes
We've been trying to figure this one out for a couple of days. Here is the code in question:
p1_y = (unsigned char) (((double) p1_y + (double)127)*.75);
if (p1_y > 250)
p1_y = (unsigned char)250;
PrintToScreen ("P1_y is %d\n", (int)p1_y);
The first line is a conversion we need to use to make our steering wheel paddles work. p1_y is the value sent to the drive motors. What is happening is the wheels spin forward until the upper limit (250) at which point they immediately spin backwards or stop. Output from the print line reflects this condition, increasing to 250 then converting to 1 or 127. We thought maybe the steering wheel had started to send the wrong signal at its limit, but changing the limit set point (i.e. from 250 down to 245) results in the same thing. Any ideas?
Unread 02-02-2006, 09:58
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Strange but...need fresh eyes
if (p1_y > 250)
Are you overflowing?
Does p1_y go from -128 to 127, or from 0 to 255.
If its from 0 to 255, then adding 127 definitely takes you out of the range of an unsigned char.
If its from -128 to 127, then it seems that saving (127+127) to a signed char would also result in overflow.
If you want to scale by 75% you can multiply by three, then divide by four:
p1_y = 3*(p1_y + 127)/4;
No need for floats.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 02-02-2006, 15:08
AKA: Dan
No need for floats.
Well the first line of the code works ok I believe. p1_y from the steering wheel goes from around 60 to 150 or something like that. The correction fixes it ok. If I change the if statement to, say, 254, the code will work correctly until 254 then flop to 1. If I change the if statement to 145, the code will work correctly until 145 then flop to 1. So I am deducing that my assignment in the if block is causing the headache. That being said, I am going to try what you suggested, because once things over range, all logic can be thrown out the window!
Unread 02-02-2006, 15:24
AKA: Dan
Another idea I had was to maintain my drive variables as int to avoid overranging and then of course make sure they are 0-254 before sending them to the PWM ports. That way if there is any spurious or temporary overranging, I won't lose control of the variable. Because no matter how you look at it, if you take and unsigned char with a value > 127 and add 127, then you have over ranged even though subsequent operations are designed to bring it back into range. With ints this shouldn't be a problem right? Unless I really, really really, go out of range.
Unread 02-02-2006, 17:12
Joel J's Avatar
do you..
Yep. with a signed int, you can go on the range: [-32768, 32767].
Joel Johnson
Strange Behavior Gary Bonner Control System 17 09-11-2005 19:01
Strange products upon running code... neilsonster Programming 17 10-08-2005 00:20
strange error Anthony Kesich Programming 2 25-02-2004 18:55
"Regional Competition Edition" of Fresh From the Forum Ken Leung CD Forum Support 5 21-03-2002 08:21
