Go to Post Now I'm having visions of thousands of balloons and a grumpy old man. Oh, and a talking dog. No talking dogs on the field. Grumpy old men are ok - sometimes. - JaneYoung [more]
Unread 02-06-2006, 08:40 AM
Maxi Block Wiring Technique
Now that teams are really getting close to finishing, I wanted to remind everyone who are using the Maxi block of a few things. Make sure when you insert the #6 that all wire strands are inserted before tightening the holddown screw. When you insert the #10 on the output side, strip 1" of insulation from the end of the wire and fold over the strands before inserting into the block. You may have to "form" the bundle with pliers to get it to fit, but it makes a much more reliable connection when you tighten the screw. I would not recommend #12 wire be used in this application although a similar technique may give you a lower resistance connection.
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 03-30-2004 10:45 AM
Warning! Check the screws on your Maxi fuse block! Roland Electrical 1 03-16-2004 09:59 PM
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 08:38 PM
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 02-20-2004 07:19 AM
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 01-23-2003 12:46 PM
