lighted switches not allowed
I read some where it is not allowed to have lighted switches on the custom control box. Is this true?
Re: lighted switches not allowed
Read Section 5.3.8 (Manual page 18), also known as Operator Interface rules. Nothing there about not having lighted switches, however you need to power the lights from a Joystick port (<R78>).
that wouldn't fry the OI? and do u know the pinouts of the joystick port?
The pinout and other important information about the joysticks is available from Innovation FIRST in the OI reference guide, available here: http://www.ifirobotics.com/oi.shtml |
"LED Drivers (see pinouts on pages 7-10)
PORT 1 and PORT 3 each provide four LED output drivers. These LED drivers allow the connection of external LEDs that duplicate the function of the top eight Robot Feedback LEDs on the Operator Interface. The LED drivers provide 5V that is current limited to 10mA. Connect the LED’s anode to the desired LED drive pin. Connect the LED’s cathode to any ground pins." This is from the 2005 OI manual. From what I understand, the LED driver output pins 5,8,9,15 will power an LED, but I'm not sure about a lighted switch. The pin 1 +5v is for the joystick pots and other analog input devices. It only provides 100mA. I believe it's legal to use lighted switches, but you need an external power source. Would someone else please chime in because we want to do some feedback on the control board and the OI doesn't put out enough power for LEDs and switches, as shown below. "[2] LED drivers provide 5V at 10mA [3] +5V Aux is to be used for potentiometers in Joysticks and custom I/O boxes. [4] Do not use +5V Aux for lamps or LEDs. [5] The current limit of the +5V Aux from all 4 ports is about 100mA. The Aux Fault illumination when the current draw from the +5V Aux Outputs total about 120 Aux voltage will have dropped to about 4.5 volts. Worse case, short condition: seconds, the voltage will be at about 300 mV with a current of about 250 mA." |
So, if you follow the method chrisinmd proposes, you won't be allowed to use a lighted switch. |
#7
While they may or may not work on the joystick ports, they do work on the competition port. Yes, we have lighted disable/auto switches.
#8
Why not just use a switch that is easy to see the position of and has good labels on the board?
#9
| Alternative to limit switches? | RbtGal1351 | Electrical | 27 | 10-12-2005 15:30 |
| Robot Cart Switches | Chaos204 | Electrical | 6 | 23-06-2005 20:57 |
| Team selector switches on ISAAC | Lloyd Burns | Robotics Education and Curriculum | 0 | 17-12-2002 08:32 |
| Need help with custom switches | archiver | 2001 | 3 | 24-06-2002 00:35 |
| Can I use any type of switch on my controler interface? | archiver | 2001 | 5 | 23-06-2002 23:09 |
