Go to Post I love it when the robot's develop personality quirks. - Mark McLeod [more]
Unread 07-02-2006, 21:04
jax1488's Avatar
jax1488 jax1488 is offline
The Northern Chicken Wizards
AKA: jack stone
FRC #0522 (Robo Wizards)
jax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to all
Send a message via AIM to jax1488 Send a message via MSN to jax1488 Send a message via Yahoo to jax1488
ball speed rule?
if u do happen to be able to shoot the 3pt goal and 1 pt goal.. but in order to shoot the 1pt goal, the ball had to be on a spin foward. now when the ball hits the ground of course it will make the ball spin along the ground increasing its speed... is that in violation of the rule? and is it that when the ball gets shot out at normal speed or hits the ground making it go faster.. which is what violates the rule?
Unread 07-02-2006, 21:16
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: ball speed rule?
The answers I've seen so far would indicate that the speed limit is only as the ball leaves the shooter. Any extra speed, forward movement added speed, spin as you describe it are OK. As always the best bet if you are really worried is to post your question on the official First Q and A.
Unread 07-02-2006, 21:17
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Originally Posted by <S02>
Muzzle Velocity - No ROBOT may throw a ball with an exit velocity of greater than 12 m/s (26.8 mph). As a reference, a ball traveling at this velocity when leaving the ROBOT at an angle of 30º from horizontal with no spin will travel approximately 35 feet. A robot that violates this rule will be considered unsafe per <S01>.
Since the rule says 'exit velocity', it indicates the speed of the ball when it leaves the robot.
My opinion, it would be legal.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 07-02-2006, 21:18
The rule is MUZZLE velocity. If it leaves the robot at 12 m/s, then goes faster after ejection, that's not your problem.
Unread 07-02-2006, 21:25
jax1488's Avatar
AKA: jack stone
ball speed rule?
sweet... ok then makin sure :-D
Unread 08-02-2006, 11:16
Godzilla!'s Avatar
Godzilla! Godzilla! is offline
a
AKA: Ron Webb
Godzilla! has a spectacular aura aboutGodzilla! has a spectacular aura about
Red face Re: ball speed rule?
I believe that you are missing two other pieces of the equation -
1. Gravity - Can't live without it
2. Friction - Every time that the ball is in contact with a surface it will slow down proportionally to the coefficient of friction between the ball surface and whatever it touches.
Adding additional momentum to a ball after it has exited the "shooter" without violating the "shooter definition" rules would be kind of difficult at best.
Unread 08-02-2006, 14:19
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Maybe not.
Take a normal two wheel shooter with the wheels vertical and one wheel above the other. The wheels spin in opposite direction to shoot the ball.
But, if the wheels are spinning in the same direction and have some assistance to keep the ball between them, you could put a LOT of spin on the ball.
Then, just drop the spinning ball on the ground. the "exit velocity" is close to zero. Gravity accelerates it towards the ground and as soon as it hits, the spin will shoot the ball in the direction of the spin.
How much and how fast, I don't know and don't have the time to calculate the inertia of a spinning ball at 5000 rpm or something hitting the ground, with friction, accelerating x ft/sec... But, I bet it would accelerate some...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Speed Sensor for Ball Shooter Justin Stiltner Electrical 15 28-01-2006 14:40
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Low quality 2X ball? Rob General Forum 16 22-04-2004 22:36
