Go to Post You play your best, the refs do their best, and at the end of the day we are FIRST, collectively. - KenWittlief [more]
Unread 07-02-2006, 21:07
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Emergency Help Needed on Main Board and Camera
Note: this is an blurb of the e-mail sent to IFI.
Next, when we turn on the robot, with the default cmucode, the terminal windo just says >ifi when reset/turned on and nothing else; even with debugging mode turned on in the code. Kevin Watson, who wrote the default code, states in his FAQ that if nothing is returned, the main board is bad. Is this our case, or are we doing something wrong with the camera. We have all the connections (ttl, servos, power, etc.) made properly and the code is default, and the servos seem to not be getting any power, since the rotate freely(thus the need for the diagrams to trace where power is lost).
Thanks.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 07-02-2006, 21:18
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: EMERGENCY HELP NEEDED ON MAIN BOARD AND CAMERA
make sure you have the OI connected to it either via tether or radio.
Unread 07-02-2006, 21:24
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
If the servos are turning freely, they are probably not connected to the RC at all (if they are connected to the right PWMs, they should be trying to track the target. If they were connected to an unused PWM output, the combination of power and a neutral - 127 - signal wouldn't allow them to be easily turned.)
We get the symptoms you describe (nothing pops up at the terminal) when the battery is dead, or when the camera has been turned on after the robot. A fresh backup battery in the first case or a reset in the second case should do it.
If that doesn't help, then you probably have a bigger problem.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 07-02-2006, 21:35
Steve S.'s Avatar
Steve S. Steve S. is offline
2008 FIRST Volunteer =D
FRC #1591 (Greece Gladiators)
Team Role: Webmaster
Steve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the rough
Send a message via AIM to Steve S. Send a message via MSN to Steve S. Send a message via Yahoo to Steve S.
Double Check your connections
Unread 07-02-2006, 21:38
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
All-together you should have 4 PWM type wires coming off the "camera mount" to the controller.
-2 from the servos to pwm01 pwm02
-1 TTL port (w/ TTL device) to camera
-1 power from a PWM output to camera
Are the lights on the camera at least on?
MOST IMPORTANT... BACKUP battery!
Unread 07-02-2006, 21:47
I have triple checked our connections
I was thinking that the backup battery might be the problem, so I will change it tommorow.
No, the radio was not plugged in, so we will try that manana tambien.
Thanks everybody
for the awesome help
Unread 08-02-2006, 15:14
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Thanks everybody
we were having that problem. do you have a dongle plugged in to initiate autonomous.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 08-02-2006, 15:40
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Emergency Help Needed on Main Board and Camera
when that happened to us, we recharged the battery. Try that
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 09-02-2006, 21:22
It was the lack of Operator Interface ... now to just make it to not see flourescent lights.
Unread 07-02-2006, 21:46
Free-turning servos can indicate no power getting from the backup battery to the pwm port pins, but they are also a symptom of the RC being disabled. That'll happen automatically if there's no communication with the OI. Make sure you have either a red tether cable between the OI and the RC or a pair of functioning radio modems connected. If you're using a competition port dongle, make sure it's not disabling the robot (the yellow light on the OI should be off).
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
