Go to Post It shouldn’t be about whether or not you think it’s easy or not, it’s about whether or not you think the effect of the change would be a positive step for our country. - Bill Gold [more]
Unread 08-02-2006, 23:25
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
I fixed the Codec problem
Yes you read it I fixed the codec problem everyone been whining about. My solution: Take a step back away from your monitor and watch your entry. Your too used to seeing everything perfect in your entry. It worked for me.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 09-02-2006, 00:12
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
Re: I fixed the Codec problem
Ok, I think I have found the bottom of this codec issue. Seems that Apple came out with a new, improved, DV-NTSC codec with Quicktime 7. Also, if you have QT7, but installed certain other codecs afterwards, it changes the Apple DV codec to a different one, which does not play very well in Quicktime. To fix this issue, install (or reinstall) Quicktime 7 from the link below, and then rerender your animation on the highest settings (4:3 Progressive Scan worked best for me). My animation looks sharper than I've seen it before, even the raw uncompressed version, and is only 135 megs.
Helpful links:
http://www.m2w.net/reviews/dvcompression9808.html - Read about DV-NTSC.
http://www.apple.com/quicktime/download/win.html - Quicktime 7 DL Link.
I think if you looked back over the other, EXACTLY THE SAME thread, you might find your answer, possibly a better one too.
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Problem w/Mesh Kevin Thorp 3D Animation and Competition 4 17-02-2005 23:04
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
