Go to Post If you are new to these forums, you might want to observe the discussions a while before diving in with opinions, emotions, and expertise. - Andy Baker [more]
Unread 09-02-2006, 08:10
karpiron karpiron is offline
FTA
karpiron has a spectacular aura aboutkarpiron has a spectacular aura about
pic: Team 225 BEAR-O-Metric
Unread 09-02-2006, 08:11
Billfred's Avatar
Billfred Billfred is offline
Re: pic: Team 225 BEAR-O-Metric
Looks pretty solid.
Just curious, how do you plan to keep that ramp out of the ball corral? It seems like one good whack from behind would put you in there, and thus put you in danger of a DQ. Of course IANAE, so I may be dead wrong.
Either way, it looks like a winner.
Unread 09-02-2006, 08:24
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Looks like a solid design. I like the simplicity.
Out of curiosity what do you plan to use for belting?
Unread 09-02-2006, 11:30
FTA
McMaster-Carr
3 ply neoprene conveyor belt (.080")
Unread 09-02-2006, 11:29
FTA
Originally Posted by Billfred
Looks pretty solid.
We have a optical sensor to detect the ALU Goal Ramp.
Automatically opens the door AND prevents driving into the Goal opening.
Unread 09-02-2006, 11:44
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
This may help for you driving into the goal but what about other stronger robots pushing you into the goal. It will still be your fault and I can tell you now, if you get to that goal there will be a robot right behind you.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 09-02-2006, 15:15
FTA
Behind us is EXACTLY where we want you.
I can't reveal ALL we have up our skirt (anti-pushing algorithm).
Unread 09-02-2006, 15:21
DjAlamose's Avatar
AKA: Teh Albie
An algorithm wont help if the robot behind you moves at 10 inches per minute and has the gripping power of a belt driven not tread driven robot, hint hint*
*not really
2004 GLR Champs
Unread 09-02-2006, 15:25
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Beautiful design. I love it. It looks like it would be very effective. Just out of curiosity, how are you getting around rules <S03> and <R04>? It looks as if your drawbridge ramp is outside the starting 28x38 foot print thus violating <S03> and it can let down between 0 and 8.5" from the floor violating <R04>. You might want to double check the discussion in this thread.
Unread 09-02-2006, 15:32
Courtneyb1023's Avatar
Courtneyb1023 Courtneyb1023 is offline
AKA: Courtney
Courtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to beholdCourtneyb1023 is a splendid one to behold
From what I understand, assuming that the ramp is just a ramp and isn't propelling it in any way other than gravity, the ramp is within the guidelines of rule <S03>. However, your ramp looks like it is less than 8.5 inches off the ground, and is not within 10 degrees of vertical. Your ramp very well might violate rule <R04>.
Unread 09-02-2006, 15:38
Actually, the conveyor roller at the top right of the hopper looks like it will be providing the final impulse to put the ball into the large hopper then the ball feeds down the chute to the ramp thus gravity may not be the only impulse. This may or may not violate the <S03> rule depending on how you read the latest Q&A discussed in the thread I linked above. The "shooter" in this case is the conveyor rollers in the top of the hopper. I dunno???
Unread 09-02-2006, 15:41
FTA
Re: (S03)
FIRST Q/A answered this issue of a ball release by GRAVITY. (1-26-06)
We can not use the conveyor while the door opens - separates the two functions.
Re: (R04)
Our door rotation is limited so that the front face is not more than 5 degrees from vertical.
Unread 09-02-2006, 15:47
AKA: Courtney
Sounds good! Great design! I would make the sides of the ramp taller to prevent anything pushing you into the goal, even with the algorithm.
Unread 09-02-2006, 15:49
Re: (S03)
We can not use the conveyor while the door opens - separates the two functions..
Pretty smart idea!
Re: (R04)
Looks like you covered your bases! Great design.
Unread 09-02-2006, 20:31
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Is 5 degrees enough slope to move the balls in quickly enough?...Just a thought. As for being pused in, I would also make the sides of the "ramp" taller so it gives you some kind of protection from going into the goal. Again, just anouther thought. But it appears to be a very solid and simple design with the potential to be a big scorer.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Need Help and Suggestions - Creating a TEAM Freddy Schurr Team Organization 7 30-03-2005 22:00
What's the best organizational structure for photos? maikull Chit-Chat 2 17-03-2005 17:47
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
